Question about Kenwood KAC-8103D Car Audio Amplifier
Sony gtx 500 cd deck/ kenwood 8104d tuning
I have a sony ,in dash gtx500 and a kenwood mono amp ,, i have a big time ,proplem with the tuning , to get the most and best sound , where do you start to tune and set all the adjustments.............thanks jb
  • mongoisme33 Feb 21, 2009
    i have a kenwood 8104d mono amp and two ''12 rockfor fosgate subs and a sony deck. what are the best settings for my amp like the bass boost and stuff
Set your HPF and LPF on the headunit to match the crossover on the kenwood amp.
I have the same amp, it's really not difficult to figure out. Try these settings, For the AMP: Bass Boost: 0 Crossover: 150 Level: 1
Now just go into the menu for your head unit and make sure you set the crossovers to 150 or whatever option you have, just make sure they match.
Simple.
Posted on Dec 19, 2008
Kenwood CD player
Most car audio devices (like head units and amps) require a REM (remote) line to be connected to a switched power connection. This switched power is on when the car key is set to ON or Accessories.
Not knowing what Sony unit you had, I can't be sure, but it is likely your Sony had higher voltage preamp outputs than the Kenwood, as the KDC315 has 2V outputs.
Jun 30, 2017 | Car Audio & Video
Why is my deck not controlling my subwoofer level?
If your Sony receiver has a separate sub output, it probably has a fixed level for application to a powered sub. Your mono amp can only boost the fixed signal level it receives from your receiver. The receiver can't drive that mono amp harder
Jun 05, 2013 | Sony MEXBT5700U CD Receiver Bluetooth...
Amp is not operating at full potential also red portectant lite comes on kenwood kac-8104d
make sure all your wires you are using to connect the amp are 4 gauge check your ground make sure its drilled threw thick metal scuff off the paint that its grounded too and check how you have your subs wired see what ohm there wired in the you can get more power out the amp in 2 ohm then 4 ohm
Mar 31, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Dec 13, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Nov 07, 2009 | Kenwood KAC-8104D Car Audio Amplifier
I Have A Sony Xplod GTX GT710 Cd player in my truck. And I have been trying to figure out how to balance the bass to my subs and leave the treble to the rest of the speakers. How can I Do this?
the trick is not to use you deck to control the bass. use the amplifier and set all you radio setting to 0 this will allow you to fine tune a little audio when you need to, make all your bass tuning setting at the amp. not the deck,
Sep 02, 2009 | Car Audio & Video
AMP
That amplifier is only stable to 2 ohms.
You will only be able to use one Dual 4 ohm Subwoofer wired in parallel (all + to + on amp.... all - to - on amp.
This will yield a 2 ohm mono load.
It is impossible to wire (2) dual 4 ohm voicecoils to achieve a 2 ohm mono load.
If you're set on using both subwoofers - they will not be getting as much power from your amplifier with a 4 ohm load - but it is your only option.
SEE THIS LINK for the wiring diagram.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 02, 2009 | Kenwood KAC-8104D Car Audio Amplifier
I have the kenwood kac-8104d amp and it lights up and everything, but it doesnt power my subs hooked up to it. I have no idea why because theres power going through andd the amp is turning on. Any help?
Check your RCA's from the amp to the deck, make sure it's on an output not an input on an aftermarket deck,and the input, not the pass thru on the amp. If you have it hooked up to a factory deck, you've opened a whole new can of worms! If its a factory Deck; Post the make and model of the unit if you can find it, as well as the vehicle year make and model. I get as much info as I can on it and walk you thru the details. If it's aftermarket and you've checked the above, post the make and model of the deck and I'll do the same. Hope this helps
Jun 23, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Amp wont turn on
Double check all of your connections. I know this same problem has happened to me and come to find our that all the problem was the fuse blew that is connected between the radio and amp. Also check you battery connection. Corrosion on the power cable will also cause it to have a bad connection.
Mar 15, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Kenwood KAC-8103D Car Audio Amplifier Logo
457 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
