Question about Refrigerators
My GE Fridge is icing up in the freezer. I had a GE tech come in and he glanced at it briefly and said it was the defrost heater. I looked online and learned that it could be either the defrost heater, the defrost timer, or the defrost thermostat. How do I know for certain it is the heater, and then how do I replace it if this is the case? I see no online directions on the defrost heater and looks like I could buy one for about $60.
  • 55 Answers
If you can get to the terminals of the heater, check the resistance with the ohmmeter setting of a multi-tester. You should get a reading of perhaps 10-15 (?) ohms if the heater is good. Or remove the heater and connect it to a 110 voltage source directly and see if it heats up. Be careful!
Posted on Feb 27, 2008
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
My freezer coils are completely iced over. How do i fix this?
Its defrost problem.You need to first try manual defrost procedure.This will completely defrost the ice.But if again after few hours or few days, same problem is noticed of coils getting iced, then its defrost problem.--------- In defrost problem, mostly fridge section section stops getting cool.It cools but not properly.----- And freezer section works properly. ------------
The manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 11, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I'm really pissed. Ive had my fridge fixed twice and its still doing the same thing. The freezer is not self defrosting and the fridge part is not getting cold. it was fixed profressionly two months...
Either the defrost control is bad or the heater is bad, Only two things that could be happening, ice building up on the evap. coil needs to be removed by defrosts cycles, not happening. Find a better Tech.
Jun 27, 2011 | Refrigerators
My ge profile arctica fridge is reading about 42 degrees, but the freezer side is working fine . Its about 5 years old, a tech took a look at it and said the fans and fuses looked fine... any ideas?
u probably are starting to get an ice up behind the freezer compartment or your fan has stopped blowing the air into the freezer first thing is to make sure the fan is blowing the cold air into the fridge side if not then there is your problem if you do feel the fan blowing then you would have to carefully remove the rear panel and check in the areas that have willcall them holes tat go into your fridge if they have ice built up inside of them if they do have ice then you have a defrost problem and would have to be aqble to perfom a continuity test on the deforst thermostat and the defrost heater if both of these are fine the next thing that you would look at would be your defrost timer check for the air and the ice and if you stillhavent found the problem write back hope this helps
Jul 21, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile PSS26PSTB refrigerator ice melts inside icemaker
when you open the freezer door do you hear the fan blowing,you could have a bad evap fan motor,also if there's ice on the back wall you have a defrost problem,take off the inside back wall of the freezer where the ice is,you need to shut the control off and melt out all the ice,g.e. has had alot of problems with their computer boards which is a very expensive part number WR49X10152 around 200 bucks,look behind the kick plate on the bottom of the fridge and hopefully the tech sheet will be there,it will tell you how to put the machine into defrost,do this first before you melt anything out or before you touch the control,i think you click the lite switches together 5 times to make it go into defrost,it should tell you on the tech sheet,if ithe heater doesn't come on you need to read out the heater with a meter to see if it's good also read out the defrost thermostat,you have to check the thermostat while it's cold if the t-stat warms up you won't be able to check it, you should change out the t-stat anyway so you can cut the wires going to the t-stat,bypass it by connecting the wire directly to the heater and click the lite switches 5 times and the heater should come on,if it does leave the heater on to help you melt it if the fan is running on the freezer side,click the lite switches 5 times and the fan should shut off and then you'll know it's in defrost,the heater should come on ,if the heater and t-stat read good and it won't go into defrost then it 's the board,also you can take out the board in the back of fridge ,unplug it first and look at the board for burn marks on the back or on the soldered spots,the board tells it when to go into defrost and melt the ice off the coil and like i said g.e.has had a lot of problems with the board,if you need any more help let me know,good luck
Mar 24, 2010 | GE Profile Arctica Stainless Steel Top...
Side by side refrigerator the refrigerator does not get cold but freeze works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jan 01, 2010 | GE GSS25JFM Side by Side Refrigerator
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Need help finding the defrost timer in GE fridge !!
frigidaire Model frs22zrg Water leaking into the the dispenser (where you put the glass. Also the ice dispenser become iced and where the ice comes out.
The moisture is inside of the freezer part, may need a time or the heating coil is not working.
Aug 08, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Ice building up in freezer
Due to the frosting up, The glass defrost heater broke. Any good tech knows this happens. The defrost heater must be replaced. If this is a GE side by side. The new replacement heater has dual elements. The standard heater that was put in them, was not large enough to defrost the coils fully. Replace heater and you should be fixed up. I would also replace the thermostat while you are in the freezer section they are only like 15 bucks and this way you will have a new defrost circuit.
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Jan 13, 2009 | GE 22.0 Cu. Ft. Side-by-Side Refrigerator...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
