Question about Dishwashers
HELP WITH NON FUNCTIONING DISHWASHER
THE LIGHT 3RD DOWN SHOWING AN ARROW POITING RIGHT TO A VERTICAL LINE DOWN IS RED AND FLASHING AND NOW WILL NOT LET ME PROGRAMME TO ANY MODE AND MOTOR SOUNDS BUT NOTHING IS HAPPENING
Dishwasher start light flashing & also dry light flashing, programme won't work. Also water didn't drain from the last time it washed
  • Anonymous Mar 25, 2014
    warning light comes on symbol is an arrow pointing right and a line in front of it up and down
Similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Posted on Feb 27, 2008
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
B&d control a door mpc2 model not opening control panel has flashing green up down light and also flashing red light limit set
Check your user guide if available. It sounds like you haven't set the door open limit, so press the up arrow & fully open to the door & push set, do the same for the down arrow until door is completely closed. Push the set button again & the door should be right..
Apr 19, 2016 | Building Materials
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Will not come on. red light flashes 4 times
    Never a good sign when you have red flashing codes
    4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
    Please rate my help++++Thanks for using FIXYA
    May 28, 2010 | Sony KDS-50A2000 50" HDTV
    Red arrow poiting down
    If I'm right, and this vehicle is a stick, this model has shift indicator lights. Green arrow points up when its time to shift up, and red arrow points down when you need to downshift. If it does, the tach, which registers the motor rpm's, which controlls the lights, is malfunctioning.
    Feb 03, 2010 | 2003 Pontiac Sunfire
    My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
    The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
    Sep 19, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
    Flashing symbols
    Is there another part to the error code besides the 8 like a letter in front of it?
    Jul 18, 2008 | Sharp AR-M205 Copier
    Dishwashers Logo
    438 people viewed this question
    Top Dishwashers Experts
    Marvin
    Marvin
