Question about Seagate (9W2892-337) 80 GB Hard Drive
Can not convert it to fat or fat32 file system
I m useing the drive as external hdd. but as per my requirement i need the file system in fat or fat32. But whenever it is linked to my pc runned on xp professional service pack 2  the only file system shown at the time of formatting is Ntfs. The other hdd can be formatted in fat or fat32 in the same pc.So pl suggest me how I can format the same in fat or fat32.
  • Anonymous Feb 28, 2008
    my problem is the same though i was useing disc management at the time of new partitioning. I allready told that at the time of formatting by useing disc management its not showing any other file system except ntfs.
    Master:
  • 518 Answers
Using disk manager, try to delete the partition. Then start over again.
Hope that helps...
Geno
Posted on Feb 27, 2008
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
Tip
Convert FAT or FAT32 File system into NTFS
You can increase the performance of your computer using NTFS (New Technology File System) hard drive volume with windows XP, because this advance file system provides some extra features, for example security, reliability, file encryption and Compression features.
But if you are still using old file systems like FAT or FAT32, you can covert it into NTFS with a simple command. The interesting thing is that you can convert your hard drive volumes file system without losing data on the drive. Follow the giving steps to convert FAT or FAT32 partition to NTFS:
  • First go to Start button then click on Run option.
  • Now type here “CMD” and press Ok to open command prompt.
  • At the command prompt type convert drive letter name: /fs:ntfs
  • For example if you want to convert drive E to NTFS then the command will be “convert e: /fs:ntfs”.
  • Now restart your computer and enjoy NTFS features, but keep in mind you cannot covert back it to FAT or FAT32 again.
on Jan 29, 2010 | Computers & Internet
My new Toshiba STORE ART 3 1 TB external Hard Disk is not working. i plugged it to my pc on windows 7. and it shows the drive in My Computer but when i opened it it saying that 'Please insert disk into...
Open your command prompt and format the drive type format volume [/fs:file-system]
volume: Specifies the mount point, volume name, or drive letter of the drive you want to format.
/fs:
file-system: Specifies the file system to use FAT, FAT32, or NTFS Floppy disks can use only the FAT file system.
Example.........FORMAT E: /FS:FAT32.....Press enter. E: is my second drive
May 19, 2011 | Computers & Internet
Free space on my external hdd
If your External HDD file system is configured as FAT32 instead of NTFS, the max file size limit . By using NTFS, you get increased security, file compression, disk quotas, and encryption—features you don't get with FAT.
To convert the default (FAT32 to NTFS):
1.
Close all open programs to avoid loss of data. Be prepared to restart your computer.
2.
Open Command Prompt, and at the command prompt, type convert C: /FS:NTFS, where C represents the drive letter of the disk to convert. Press Enter or Return on the keyboard.
3.
Wait while the process completes. Don't do anything while the conversion is taking place.
You can also open a Command Prompt from the Run line (available from the Start menu). Just type cmd and press Enter.
Other useful links:
http://en.wikipedia.org/wiki/File_Allocation_Table
http://windowsitpro.com/article/articleid/38803/understanding-file-size-limits-on-ntfs-and-fat.html
May 19, 2009 | Western Digital My Book Home Edition 500...
How to convert RAW to FAT, FAT32
I'm facing big problem. Hdd was in RAW format and I want to convert in fat32.
Apr 12, 2009 | Computers & Internet
Copying Files to PS3
Check what the "File System" type is by going to Start, Control Panel, Administrative Tools, Computer Management, Disk Manager. Select the external drive and read the "File System" type. The file system type must be "FAT32" in order for the Playstation to recognize it.
  • If the file system type is "NTFS", right click and select "Delete Partition" or "Delete Volume" for Vista.
  • then recreate the partition but do NOT format it. Make sure you assign a drive letter (for this Tutorial, we'll use h:)
  • If you are running Windows, format the drive by going to the command prompt (Vista, right click on command prompt in start menu and click "run as administrator")and type in "format h: /FS:FAT32" (without the quotes). You may need to substitute your drive letter. (note this will not work on XP for a large hard drive - you will have to use a third party formatting utility)
  • If you are using Mac OS X, open /Applications/Utilities/Disk Utility.app, pick the drive, and click on the 'Erase' tab. Pick 'MS-DOS (FAT)' for the file system type, and click on the 'Erase' button. This will reformat the drive in FAT-32.
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Phillips 1TB HDD problem, playing movies hrough DVD player (USB)
My question would be are the movies in the right format. Just because they play on your computer does not mean they will play on you DVD.NTFS or FAT 32 would have no bearing on this. They are simply data per sector protocols and are related to magnetic storage devices.You may need the proper codec for you computer so it can make a DVD you player can play.
Dec 14, 2008 | Computers & Internet
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Seagate (9W2892-337) 80 GB Hard Drive Logo
167 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
