1st print a report, can you see the lines? Then either the drum is faulty or the laser scanner is. If the lines are not present when printing a report, make a copy and see then if the lines appear. If so, the scanner is faulty. Try cleaning the glass with glass cleaner. However, blank lines mean that bits are missing from the scanner itself and the scanner will need to be replaced.
This article provides the self-diagnostic
steps necessary to evaluate top-to-bottom streaks that appear when
copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
Think of it this way:
Suggested Diagnosis and Fix
Step
Action
Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
Perform a visual inspection for any of the following recurring culprits:
Other Possibilities
If...
Then...
Vertical lines appear only when printing...
Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
Vertical lines appear when you lay the page on the flatbed...
Vertical lines appear on ADF-fed printed copies, but
they do not appear on scan-to-network [e-mail, FTP, folder (PC),
solutions]...
