Question about AOpen AX4SPE-UN Motherboard
USB port problem
My USB-ports seem te do what they want. Sometimes they work for one time and then all the other ports not anymore. I have loaded the USB-ports new, and then also it works once. Reloading Windows works also for one connection. How can help me
Berry
  • irtara Feb 28, 2008
    Upgrade of BIOS to 2.06 did solve a part of the problem.
    Now two USB-ports from the onboard ports do not work. Does not recognise the USB-devices.
    Who can help me.
  • 57 Answers
Thinks you can do Upgrade your Bios, do windows Updates
Posted on Feb 27, 2008
It doesn't recognize USB flash drive anymore
The flash drive itself may be faulty or damaged, and sometimes this is not apparent from a physical inspection. Try attaching the drive to a USB port that you know is operational, and try plugging another USB device into that port to verify that the port is working.
Jun 19, 2012 | Kenwood KDC-MP445U CD/MP3/WMA/AAC Receiver...
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
My Acer KU 0760 keyboard is not working at all. Seem as if the computer doesn't recognize it at all. The mouse works in the USB ports, but nothing from the keyboard. Had old gatway keyboard laying...
Try the keyboard in the USB port you've been using for your mouse. Just move your mouse to a different USB port. I know, this seems like a "too simple" solution, but USB ports sometime get cranky.
A question I would have would be: have you been using a PS2-type keyboard prior to trying to use the Acer USB one? Sometimes the BIOS needs the item "use USB port for keyboard" turned on.
Oct 26, 2010 | Acer NSK8458AN Keyboard
Problem with usb port don`t work
Step 1
Before you start working on the USB port, make sure that your device is not the problem. If the computer says that the there is a new USB device but that it cannot use it, typically there is a problem with the device's driver and not the USB port. If this is the case, your best option is to re-install or upgrade the device driver. Try inserting the device to another computer. If the device works, most likely the problem is with the computer and not your device.
Step 2
Try rebooting the machine. Rebooting a computer resets all of the software to the default state and will clean up many issues. The start up process also checks all of the devices on the computer and can sometimes fix a USB port. First shut down the machine. Connect the USB device up to the computer and start it. This reboot will sometimes fix a bad USB port.
Step 3
Try attaching the USB device on to another USB port on the same computer. If the device now works, the old USB port probably has a hardware or BIOS issue. Skip to step 5 to try to fix a bad USB port through the BIOS. Fixing a hardware problem on a USB port requires working on the motherboard which is typically more expensive just adding a new USB ports.
Step 4
Uninstall your computer's USB device bus manager. The device manager controls the USB access and sometimes gets corrupted. Fixing the USB device manager requires administrator rights on the machine. The best way to uninstall the device bus manager is to right click on your computer's icon and select properties. This will bring up the hardware settings for your machine. Click on the hardware tab and select the device manager. The device manager lists all of the devices on the computer. The next step is to open up the "Universal bus controller" option. Right click on all of the items under this option and uninstall them. Once all of the devices have been removed, restart the machine with the USB device connected. Upon reboot, windows re-installs the USB device manager. Most of the time, this will fix the USB port.
Step 5
The next thing to try is to check the BIOS. Restart the machine and enter the BIOS setup screen. You should check to make sure all of the USB ports are active. If they are, you should try resetting the BIOS settings to the defaults. The BIOS reset will sometimes fix USB port. But if it does not you will have to consider upgrading the BIOS. Upgrading a computer BIOS is very dependent on the motherboard manufacturer and you will have to visit your computer manufacturer's web site for detailed instructions.
Step 6
The last trick to try to fix a USB port is to repair your OS. Sometimes the USB drivers can get corrupted and break the USB ports. You can reinstall the system files onto the computer which should fix the USB port. Your data files should not be changed in this process, but it is a good idea to do a full backup of the computer ahead of time. In windows, an OS re-install is done by loading up the windows installation CD/DVD and selecting the repair windows installation. Just follow the steps and you often have a fixed USB port at the end of the process.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 12, 2010 | Dell OptiPlex 210L PC Desktop
My usb 2.0 doesn't seem to be working with this motherboard. I've been trying to load music on my ipod, and it says I have no high speed usb ports. And it goes super slow.
Depends on the age of the motherboard it might be old.Do you get the same result from all ports.You may have two types of ports on the motherboard, check all.
Good Luck
Mar 22, 2010 | Biostar G31-M7 TE Motherboard
TM-U220 sometimes fails to print
Maybe the USB cable or the port on the PC or PRINTER is defective. First try a different cable, then try another open USB port to see if it works there. Also, the POWER CORD for the printer may be loose or defective, or maybe one of the printer DOOR INTERLOCKS may be intermittent, or not closed properly.
Nov 25, 2008 | Epson TM-U220 Matrix Printer
My wd2500 is no longer recognized by my xp pro notebook. I have used 5 different USB cables. Te power light keeps pulsing. I did get one error message with one cable that said "te usb device attached...
I assume you did reboot your computer and plugged the external HDD to other USB port but still has this issue.
I can only suggest to recover your external HDD to different computer dont rush it, sometimes it takes time to load.
Jan 04, 2018 | Western Digital Passport WDXML800UE...
Files will not load
Try reformatting the drive to factory defaults. I would also try this unit on other PCs to verify that the USB port will not work correctly. Does the USB port on your Sony Walkman MP3 player have any damage or broken pins/connectors on the USB port?
Mar 31, 2008 | Sony Network Walkman NW-E005 MP3 Player
USB Port problem?
sounds like just how it is call sony
Feb 14, 2008 | Sony Playstation 3 (PS3) Console
USB powerloss?
As you have already stated that the port in question can run a standard optical mouse, the port seems to be working fine.
Sometimes the drivers for a USB device need to be installed for each USB port. Maybe you have installed these drivers for 3 of your 4 USB ports, but not for the one in question, result of which is the problem you face.
Oct 16, 2007 | Computers & Internet
AOpen AX4SPE-UN Motherboard Logo
102 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
