Sewing Machines Logo
Posted on Feb 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Nechhi Royal Series Sewing Machine Has stopped working
I have a Necchi Royal Series Sewing Machine. The needle will not move up and down.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
276
Points
This site is useless! I ask about a sewing machine and coffee makers come up wtfo?
ken dourof
Level 3:
  • Master 980 Answers
  • Posted on Mar 07, 2010
ken dourof
Master
Level 3:
Answers
980
Questions
0
Helped
264442
Points
1919
Make sure the stop motion wheel is tight, make sure you do not have any thread stuck in the raceway area if you get a buzzing sound from the motor
Necchi heavy duty royal series. Manuel says 3205FA and 3204FB. I want to know where to oil it. I also need help because it won't reverse anymore. Any advice?
It's an old metal mechanical machine, right? It is probably seizing due to old oil that has dried. Here's my method for "unfreezing" old sewing machines. (You won't believe how good it sounds and how nicely it runs after you've give it some TLC!)
Wheel on right side that controls the needle up and down is very tight...
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
I have a Necchi 3205FA ROYAL series sewing machine. It will not sew at all the only time the needle moves is when I click the bobbin in and then it only moves for a second then stops completely.Should
Can you turn the handwheel manually? Does it move freely? If not, the machine needs to be oiled. Check the manual for the proper oiling locations. Basically, any metal to metal areas require oil. Just make sure the machine is unplugged and avoid oiling the motor.
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
2helpful
3answers
Need manual for nechhi sewing maching #4575 code150t
http://userguides.50webs.com/
They carry manuals for almost every sewing machine ever made.
If they don't have it, they usually will tell you where you could get it.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
