How do I adjust the legs of my Samsung Top Loader washing machine?
Seriously!
I am not blonde, although I have had to check about ten times this morning just to be sure. Yes, I have my manual and even googled another as the manual is clearly written out for those who do not require pictures drawn for them. I however, do! (I also got mud on the first one when trying to drain the pipes, but that's a whole other story!!)
I pulled out the adjustable legs (situated on the left and right side of the machine as promised) and was quite chuffed with myself until numerous cranking, pulling, cursing etc. did not level my drum. If anything I've made it worse as I am now one hot, sweaty, irritable woman!
It says (and I'll quote) "Pull the handles located at the right and left of the front side and slide off" Slide off where! They're firmly fitted to the dang machine! Next "Adjust the height of the machine up or down" HOW!! The handles stay on the side of the machine, they dont come to the front and no amount of yanking, pulling, swearing makes any difference. And if your one leg is longer than the other (okay, not yours, the machine's) how do you know whether you're cranking it up or down!!!!
Right, I'm going to trust you on this one and grab a cup of coffee and a smoke before I totally lose my rag and wheel the machine out onto the street!
  • Amicable Ang Feb 27, 2008
    Thanks guys. After a very hot irritable day I now have a washing machine that won't drain the water and makes a hang of a noise. I'm convinced it's something to do with the level of the drum but can't seem to get the legs sorted! Tilting does not help. These little lever things that you pull out from the sides are supposed to make life easier as you're supposed to just crank up the height of the legs. Much like the jack of a car? NOT! Thanks for your time, you've been great!
    Champion:
  • 249 Answers
Hi hot, sweaty,irritable .In most machines you just tilt it back 45o,the legs should be treaded,screw them,up,or down,to level,I don't know about the handles, new to me.Close Ireland,good luck
Posted on Feb 27, 2008
  • 156 Answers
Lol most all washer you turn the leg like a screw usely to the right to lower it left to make it longer some have a nut also on the leg that needs to be lose before leg moves so after you git he front of washer level from side to side most you just lean washer forward back will auto level some you do the same as you did in the frount
Kenmore top loader shakes in the spin cycle
The legs that it rests on are adjustable and have adjustments that commonly screw in an out. It is a must upon installation that the machine is level or it will shake itself to pieces. Get a level and put on the top of it and using a level front to back and side to side adjusting the legs underneath until it is right. This will cure your problem.
Oct 12, 2014 | Washing Machines
Samsung front loader washing machine
clean your debrise trap on washer, then check for stuff in lips of seal around door, there may also be a return spout at top of door that could be clogged , use tweezers carefully to unclog.
Aug 10, 2014 | Samsung WF337AA Front Load Washer
MY WHIRLPOOL TOP LOADER WASHER WTW6600SW2 STAYS
there are usually four adjusters at the base they are very thin and a spanner will be needed to adjust instead of a spirit level use a float bubble its circular like ten pence peice made from plastic with a bubble and cross with centering lines on it for gaining best centre position BQ sell them
hope this helps
Aug 13, 2013 | Washing Machines
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Regards,
    Richard Roth
    http://appliancecafe.com
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    How do I adjust the clutch on an ELBA Model WA50T54W1 top loader washing machine ?
    Hi.
    Unfortunately the service documentation for Elba is not available. Although the machine has been built by F&P and although is similar to a Fisher & Paykel Smartdrive there are some small difference. The clutch system may be similar to the smartdrive. I have uploaded the service manuals for two smart drive models below, see if that can help. Check section about disassembly.
    F&P top load smartdrive smI.zip
    Regards.
    Ginko
    Sep 05, 2011 | Washing Machines
    My brandt washing machine(model wtc0633) vibrate seriously
    Hi Steven. You maching is a top load type and it sounds like the leveling legs under you machine are no longer adjust properly. This can occur from moving the unit or just over time from normal use. You can verify this by pressing down individually (one at a time) on the 4 corners of the top of you unit. If it rocks when you press down or push on the the corners then your leveling legs are out of adjustment. Adjust the legs under the unit until it no longer moves when you press on the corners and see if this solves your problem. If you need more help later then reply to this post.
    Jan 09, 2010 | Washing Machines
    I have a Maytag Performa top loader that won't stay in balance
    make sure you locking the legs,
    put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
    Oct 06, 2009 | Maytag Performa PAV3200
    Washer shakes on spin cycle
    2 possible causes 1 cleanout filter and check water is pumping out properly before spinning
    2 check the suspension legs at the base of the tub for wear or damage.
    Oct 29, 2008 | Speed Queen AWS52NW Top Load Washer
    Will not balance
    The front 2 legs should be screwed in completely, and locked with the check nut. (the check nut is at the upper end of the bolt, and is a loose nut) This means the machine is lowest in the front. If you find any shake (try with both your hands) adjust accordingly, & lock with the inner check nut. Normally the machine adjusts itself if the weight is un-balanced; but it cannot do anything if the legs are uneven.
    There could be some spring or shock-absorber come loose inside the machine. Plug off the wall, remove panel behind & check. If you could remove the top to check fine. Also find out the actual capacity of the machine - look user's manual (a book which is seldom read), it would be good to actually weigh your dry laundry to have an idea. Would be nice if you rate me pl. Good luck.
    Nov 29, 2007 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    341 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
