Question about HP R967 Digital Camera
When i insert the memory card the camera freezes.
If the memory card is in the camera then i can turn it on but only the screen is iluminated and the shutter opens. but no buttons work. and the camera can not be shut off. the only way i can shut it off is by removing the battery. if i remove the memory card then the camra works fine. but the second i put the memory card in the slot then thats when the camera freezes up. the memory card is a 1 gig kodak and is brand new. it has worked fine the past few days. the camera is a HP R967
  • 1 more comment
  • Anonymous May 09, 2008
    The camera can be turned on , but the picture taking button will not take a picture when trying to depress it
  • tessa862
    tessa862 Apr 15, 2013
    Mine is doing that same thing, and I have two memory cards, it does it with both, and it worked fine last time I took pictures. Nothing I try fixes it.
  • James Hilton Jan 12, 2014
    I have the HP E317 and it is doing the same thing, the card works in my other cameras.
    Novelist:
  • 155 Answers
It sounds as if either the file allocation table or some data on the card has become corrupted.
Have you got access to another camera (friends or family) that you could try it in?
Have you got a card reader on your PC? If so, you should be able to re-format the card using Windows. (Go to My Computer, right-click on the card reader icon and select format)
Hopefully this will cure the problem. If not, you should be able to change it if it is new.
Matt
Posted on Feb 27, 2008
SD Card states error card when inserting and turning it on.
you need to go into the settings on the camera and ask it to format
May 30, 2013 | Vivitar Cameras
I received a new DVR 528. I can work through the menus when the SD card is not inserted. Once I insert the memory card the screen freezes - no buttons work!
Make sure the camera is off before inserting the card. Can your camera use the size card you have or does it have too many GB's? Is the slide switch on the side of the card in the unlocked position?
Dec 08, 2010 | Vivitar Cameras
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
Pentax otio 33lf camera suddenly won't go
Try removing the card and see if it will turn on with just the internal memory--or try different memory card if you have one.
Had a somewhat similar problem with a new 1GB card when I shut camera off while it was still saving an image. Camera would come on, take a picture all by itself and freeze up. After using a couple of other cards it magically worked on the bad card
gmcn
Oct 14, 2007 | Pentax Optio 33LF Digital Camera
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Why does my camera freeze up when I insert or remove a memory card?
The camera detected an error when the card was inserted or removed. Turn the camera off, then back on. Make sure the camera is turned off before inserting or removing a memory card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
"Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
HP R967 Digital Camera Logo
70 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
