Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Cannot make copys, as it was long time not in use
  • 159 Answers
Does it print a report? The scanner is probably dirty, just take some time to clean the scanner glass. There may even be a message to tell you to clean scan part. If not, the light source is probably finished
Posted on Feb 28, 2008
Canon G10: clicking properties on camera movie files gives creation time, but after copying to computer, properties only gives copy time, not original creation time. Where did the original time go?
If you use the camera cable or a card reader to get the photos on your computer, the metadata is there. When you copy the same picture the metadata is lost and is replaced by the new data at the time it was copied.
Mar 29, 2017 | Canon PowerShot G10 Digital Camera
How can I make my scanner auto scan
unless you have really good office unit that has that capability, it is probably not possible as you have to change the copy being scanned and that means opening the lid , putting fresh copy each time a fresh copy is needed
if it is connected to a pc or laptop there is a number to copy button that you can alter so that it scans the same document a set number of times and save you having to press the copy button each time
Dec 01, 2016 | Office Equipment & Supplies
How do you copy paste
Place your finger on the part you want to highlight , hold it there until it says '' copy '' , click on copy and do the same where you want to paste just paste instead of copy .
Dec 29, 2013 | Computers & Internet
I was copying a fairly large document and at some point the document continued to scan but stopped printing. The memory light is on and the LCD print out reads "printing" but it is not printing.
hello there, Sorry but the question is a bit confusing. Did the document finish copying or it copied half way and stopped? Or you were copying and printing it at the same time?
If you were copying and printing at the same time then the problem is expected as the procedure for printing is considerably faster than the copy process. Simply turn of the entire system either by proper shutdown or by just cutting the source of power to the unit. And this time copy the document completely first before you try printing. This should come up without any hassles.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 04, 2011 | Office Equipment & Supplies
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
I have a new photosmart C4680 printer and I can only print one copy at a time from my computer. I want to print two or more copies at a time. What do I do to make this happen ?
Usually the number of copies of a certain print job is handled by the software.
Example: You have written a one page letter using WordPad. You would like the C4680 to print 2 copies of this letter:
1) On the menu, click "File"
2) Choose "Print..."
3) On the page that follows, change the number of copies to 2. There are other options you may choose at this time, if desired.
4) Click Print
The unit should start printing 2 copies of your letter.
Jan 05, 2010 | Office Equipment & Supplies
Copy Report to Excel
Try to highlight the area you want copied and either hit <CTRL> and <C> at the same time or left click on the mouse and select copy. Go to the document you want copied and hit <CTRL> and <V> at the same time or left click on the mouse and select paste
Dec 20, 2008 | Intuit Quicken 2002 Deluxe (78588)
I just purchased a FAX-JX300,set it up,pressed Spanish by mistake,now can not clear it to put it into english.I am sure there is a simple solution but I'm definatly tech. challenged.Thanks,John.
Press [Menu], [Start/Copy] x 2, press Scroll Down button 5 times, press [Start/Copy], press Scroll Down button 2 times, press [Start/Copy], press Scroll Up button 5 times, then press [Start/Copy]..... you done it !
Apr 18, 2008 | Office Equipment & Supplies
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
James Cagle
James Cagle
Jim Keysor
