Question about JVC Everio GZ-MG130 Camcorder
Computer wont register camera
Hi I was wondering if you could help me, for some reason my computer wont register that the cam has been hooked up to it, I have a High speed usb/firewire hook up. The computer will redister that it is hooked up once the settings are switched to stills howerer it wont register live motion capture. I paid like 1500 for my camera and I dont want it to go to waste and buy a cheap web cam
If you can help me that would be great
  • Ashnkatt Feb 27, 2008
    Also I am trying to hook the camera up with Windows movie maker or Adobie Photoshop 5.1
    Once again if you could help that would be great
    Ops Running windows XP
  • 537 Answers
Check with JVC and your manual to ensure that this camera can be used as a still camera when connected to the PC. I think even some high end cameras do not have this functionality.
You don't say which version of Windows you are running.
I would check with JVC's web site or on your driver disc to see that there are WDM / TWAIN drivers to allow your GZ-MG130 to be seen as an imaging device in Windows.
Posted on Feb 27, 2008
My 2000 2.7 intrepid is having to turnover for about 4 seconds to start i replaced the cam shaft position senseor it wont start if i unhook the sensor it starts
change the sensor its probably a safty feture bult into the car thats why i hate modern cars for this reason lol
Sep 21, 2012 | Cars & Trucks
ı hawe a problem whit the cam
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
Having proved your cam is working ,you can configure it to WLM (MSN)
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jan 08, 2010 | Microsoft LifeCam VX-3000 Web Camera
Hi Val,
The mode select has three options. Camera, Video and PC Cam. It needs to be set to PC Cam to give you live video.
Best regards,
Jan 02, 2010 | VistaQuest VQ-7015 Digital Camera
Web cam troubles
To simply use a web cam, no special software is required other than its driver. It becomes an input device on your computer. Many of the programs already on your computer can make use of the camera -- at least to capture still photos.
However, the ability to do tricks and other special things does require special software. It is probable that you camera came with software to do just what you describe already on its installation CD. You simply have to install it.
I hope this helps.
Aug 15, 2009 | Acer Aspire One A150-1006 Notebook
Firewire Problem - HELP!!!!!
make sure you are using 4 pin to 4pin firewire which looks like this:
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Mar 27, 2008 | Video Cameras
My web cam
uninstall the software for that camera. then restart your computer. after restarting, re-install the drivers for that camera.
this may work. if this still doesnt solve your problem, try jumping from one usb slot to another.
Mar 24, 2008 | Computers & Internet
PC Wont register Camera is connected
If it is a cam corder, a lot of them only work for stills once hooked up to the PC (via USB). Are you certain the cam be used via a computer.
If the camcorder contains both USB and IEE1394/firewire and your computer has both USB and firewire, then sometimes the USb interface is set to stills only and the firewire interface is set to motion only.
Which make/model?
Feb 27, 2008 | Cameras
I believe you need the USB cable and you hook it to the computer and install the software that came with the camera and it should work, I have an A520 and at one time I had it hooked to my computer and really never hooked it up as webcam but I believe the option was there
Dec 12, 2007 | Canon PowerShot A520 Digital Camera
For the first user, The screen will cut off on the camera when you plug it into your computer. That is the way it's supposed to work. Make sure your camera is set to webcam. That will be under video resolution in your tools and settings screen. Looking at your camera, it will (or should) be the bottom left button. The camera won't work properly on your computer in Hi Def and that's probably why Yahoo won't recognize it. The resolution is just way too much for it to handle. Hope this helps some.
For the second one, did you install your driver software? Good, had to ask, don't cuss me! (HaHa) Okay, plug in your camera, open the little viewscreen on your camera (this MUST be open or you'll only charge your camera, go to my computer, then to whichever drive your camera is hooked to. It's removable media "L" on my computer, but yours may be different. Click (or double click) on that. You should see an icon that says DCIM, double click. Click on 100 media. Your files should come up. Hope this helps.
Nov 11, 2007 | Aiptek A-HD 720P Flash Media Camcorder
PC-CAM 880 - remember Webcam mode
Uninstall all reference drivers to camera, reboot then install drivers again AFTER you hook the camera up to your computer.
Drivers can be found by clicking HERE.
Sep 12, 2005 | Creative Labs PC-Cam 880 Digital Camera
JVC Everio GZ-MG130 Camcorder Logo
136 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
