Question about Kenmore 24 in. 16034 Built-in Dishwasher
Does not go thru dry cycle, clean light blinks 7 times
I cannot seem to get this problem fixed. Dishwasher stops mid-washing cycle and clean light blinks 7 times. It then needs to be reset. My repairman has replaced the control panel and door latch. This has not helped. We have already spent $250 and still do not have a working dishwasher. Any ideas on what will fix this problem?
  • tech 302 Apr 03, 2008
    clean light blinks 7 times... Have never had this problem until installing a tankless water heater , and using a delay cycle. How do I get the washer to reset? Have tried cycling power etc but no solution yet. Is there a manual reset on the unit?
  • Anonymous Mar 31, 2014
    washer will not start door latch checks ok-c/b reset no help
    President:
  • Kenmore Master
  • 2,651 Answers
Clean light blinking is a tricky problem to find and cure can be a few different issues.heres an edited down version of official manufacture explaination,its been an issue (I would call manu for assisstance in repairing this further)
A heater fault detection program has been added to the electronic control to check for temperature rise and shut down dish washer. If the temperature rise is less than the criteria, then the unit will drain and blink the clean light 7 times. The Proper incoming water temperature should be between 120°- 140° F.
Possible causes of insufficient temperature rise would include wires off at thecontrol, heating element, thermistor,inlet valve, door switch, motor or capacitor, failure of any of the above components or siphoning of the water during fill.
Posted on Feb 28, 2008
2 Suggested Answers
  • 489 Answers
SOURCE: does not go thru dry cycle, clean light blinks 7 times
Remove the front door panel and look for a broken wire.  Usually the broken wire is about 1/3 of the way up from the bottom of the door.  The wire tends to get stuck into the insulation causing the break.  Repair the wire connection and then cover the affected wire harness with a plastic cover to separate the harness from the black insulation.  If there is no broken wire, then the thermistor needs to be replaced.  That will require the entire unit removed to access from the bottom of the dishwasher.  Thermistor failures are very, very rare.
Posted on Jun 11, 2008
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Jun 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 16034 Built-in Dishwasher Logo
246 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
