Question about Samsung LN-T4671F 46 in. LCD Television
Rainbow of vertical lines during startup
Hi. I just purchased a Samsung 4071. I hooked up the TV to a standard cable connection. As I turned it on for the first time, I got a still image with the screen filled with vertical lines of all colors. (see below). There was volume as if a channel was being received but the picture would not come on. I turned off the TV and turned it back on, and problem went away. This has now repeated multiple times. Does anyone have any experience with this? Thanks much.
    Master:
  • 518 Answers
I could be a tuner problem. But since the set is new, you should return it for replacement.
Geno
Posted on Feb 27, 2008
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Hi I have a 55 inch LCD TV that while I was watching TV it went completely black when I turned it off and the on again there were rainbow vertical lines moving across the screen then at some points there...
My first thought would be to check your TV on multiple inputs to verify that it IS the TV and NOT isolated to your input cable(s). If you can get a solid blue color to come up on the screen by changing inputs then it would really narrow down the issue(s).
Hope this helps.
Jan 04, 2018 | Insignia NSLTDVD26 LCD TV
Sudden rainbow vertical lines, Loud squeel. wont turn off. Whats wrong?!
good first shut off the outlet for what is looking like this with your tv connection problems with the drain tube of images giving us the inside source for capacitors in a technical lead for the electronic exchange of capacitors and diodes for your device
Sep 06, 2012 | Samsung LN46A500 46 in. TV
Hi my tv is ultra slim fit.screen turns green from time to time with vertical lines.what's wrong with it?
hello, I think that problems occur because the connection that has been cracked. If you have experience in electrical, resoldering on the pcb crt and vertical ic area.
good luck.
Mar 24, 2011 | Samsung Ultra SlimFit 20" Digital TV
Turned on, and picture went out(just a line)with sound. never had problem with picture,but remote stop working about a year ago, cable tech said its tv not the remote
If it's a horizontal line across the face of the picture tube, your TV has a problem with its vertical output. Most likely, it's bad solder connections to the vertical output IC. Because this part gets very hot during normal operation, the connections to the circuit board can crack and the part quits working. All you see then is that narrow line across the tube. A few minutes with a soldering iron to repair the connections is usually all that's needed to fix the TV. It's also possible the part has truly failed, but the bad connections a much more common. A service shop could do the repair if you don't know anyone with the soldering skills.
Mar 29, 2009 | Panasonic CT-25G6 25" TV
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
TV will not turn on
check the resistors and capacitors in vertical section of the television..or change the vertical ic.
Dec 29, 2007 | Televison & Video
Thin horizontal line
Solder bad connects in vertical circuit,especially vertical output
IC pins.................T.
Dec 26, 2007 | Toshiba 35A44 35" TV
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Samsung LN-T4671F 46 in. LCD Television Logo
1,014 people viewed this question
Jerry Greenberg
Jerry Greenberg
