Question about Compaq tc1100 Tablet PC
Cant duplacate on extended monitor or on projector
How do you duplicate on two screens or on projector, i can only grab and move a window intothe second monitor or overhead projector screen
  • 24 Answers
Use your Q menu to select the "Internal and External" display. If this choice is not enabled on your Q menu, go to tablet settings and enable it there.
Posted on Apr 05, 2008
  • 3 Answers
Tou have to set that up in the advances NVIDIA section of the display properties. go to the desktop utilities section and check the display the media center icon on the taskbar. The choices can be made via that icon.
Posted on Mar 15, 2008
Duplication of video thumbnails on a SD external card on a coby Kyros
im guessing your on a mac, that usually what adds thumbnails. you can use a file explorer that comes with the unit, navigate to the file folder and delete them. or when you copy from a mac, do it from a finder window and not from a program and it will not do that.
Apr 20, 2013 | Coby kyros Tablets & eReaders
I have duplicate folders on the screen of my Coby 7015 tablet. How can I remove them?
On my Pandigital SuperNova Tablet, I just put my finger on duplicate and hold down on it and drag it to the bottom of screen where a trash can appears. This leaves me only on app as needed. Hope this works for you.
Jan 13, 2013 | Tablets & eReaders
Asus tf101 only half screen showing
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Jun 22, 2012 | ASUS Eee Pad TF101B1 Tablet
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the...
you need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
Oct 19, 2010 | Toshiba Satellite R10-S802TD Tablet PC
Touch screen and digital finger scan's not working
there is one option that you have tak back-up your data then run recovery disk that is only solution becoz touch screen and finger print software is realy delicate things dont try to paly with if don't have to downlod drivers from the HP site
May 14, 2010 | HP Pavilion tx2500z Tablet PC
My Epson EMP-S4 LCD projector does not display images from my Averatec C3500 laptop. It displays "No signal".. Do i have to press any keys before it would display? I suppose it would automatically project...
When you connect a data projector or external monitor to the external video port on the laptop, power up the data projector or external monitor first then the laptop. The video info will automatically divert to the data projector/external monitor automatically.
If you have already had powered up the laptop first, most laptops will allow you to toggle between the LCD screen and the external video port by pressing the Fn key plus one of the Function keys, this key will have a screen/laptop symbol.
Sep 08, 2009 | Averatec C3500 Tablet PC
Connecting to data projector
CONNECTING VIA VGA CABLE,RIGHT CLICK ON THE DESKTOP SELECT DISPLAY,
CONNECTING EXTERNAL DISPLAY,
MIRROR ON ALL DISPLAYS
WALLA AND BOB'S YOUR UNCLE
HOPE THAT SOLVES THE PROBLEM.
Jul 03, 2009 | Fujitsu Stylistic ST4110 Tablet PC
HP Compaq 2710p: External monitor does not display anything
The display properties indicate the hardware is working, so it's likely just a setting.
On HP/Compaq models you will see a picture, usually on the F4 key that looks like a screen with two lines beside it.
You need to hold down the Fn key(bottom left) and then push the F4 key at the same time to cycle between LCD, external or both.
If it is a newer model, a menu will pop up when you do this asking if you want to duplicate the LCD on the external, switch to the external or extend the desktop onto the external. Select the appropriate setting or continue holding down Fn while pressing F4 to cycle between the settings to the one you want.
If you have re-installed the computer at some point with anything other than the factory recovery set this may not work and I will have to give you a longer set of instructions.
If this works please rate this as fixed, if not reply back and indicate what version of windows you're using and I will post the instructions for the "long" way.
Chris
May 26, 2009 | Compaq 2710p Tablet PC
Toshiba M4 Graphics problems
no. i think your monitor is old. some time we get voilatie or red screen .some time it take short or long time. and some time screen moving. main cause is lose joint part in monitor it can be fixeb by soilding every parts by expert.for conform u change other monitor.then u can get result . thanks
Dec 30, 2007 | Toshiba Tecra M7 Tablet PC
Unable to connect to data projector
Hi. The Projector is recognized in Windows Enviroment as another Monitor. So right click on the Desktop = > Settings => Settings Tab => You'll find two monitors. Change to Number 2 then click ok. Now your Data from VGA Card will be redirected to your Projector Enjoy.
Feb 11, 2007 | Fujitsu Stylistic ST4110 Tablet PC
Compaq tc1100 Tablet PC Logo
568 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
