Zenith h32h38dt 32
I was given a zenith tv and I cant do a channel search. it also has a lock on it and I cant so a thing. it came with a remote control with no menu button. can you help me???
  • foldem2 Mar 01, 2008
    i'm having the same issue, there has to be a way to access the menu!!!
  • featheredsep May 18, 2009
    I have the same problem with the Zenith h27f56s.
    Have a universal remote.
    The TV will not unlock.
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
CaseyBee
Posted on Mar 20, 2008
I have this TV and a universal remote does the trick
Posted on Jun 17, 2009
How can i unlock channels? i recently was given a zenith tv. i cant unlock the channel thing in set up. model # h27c35dt
sounds like you don;t have the code to input to do that...there ware ways to reset the passcode...
an example of this would be a blurb that was posted on this website regarding a philips tv..http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=47PFL7409D/30&dct=QAC&faqview=1&refdisplay=C26_MTV_HK_LC09M_PNS_QAC_73609&refnr=0073609&scy=HK&slg=AEN you can write Zenith on teir website contact customer service, they may be able to help.
Sep 05, 2014 | Zenith Televison & Video
Cant get cable tv
Hello
First connect the cable to its cable input socket at rear.
Turn the tV On and enter its Menu option window. Press UP or DN button on the remote control to select 'Cable'. Selecte EZ scan [channel search]. The TV must scan for all available channels, and will stop after all the channels has been stored in its memory. You have to wait till the search function stops; no other functions with remote cannot be done, and the set will not respond any external command, either by remote control or by its front panel control, except the mains power ON/OFF switch will work. OK.
Nov 21, 2011 | Zenith Z50P3 50 in. Plasma TV
Cant program remote to zenith television
If it's an newer Zenith TV(LCD/PLASMA/DLP) it might be that the RC300 does not have the codes for the newer models, but if it's a picture tube TV(CRT) and the zenith codes given to you in the code list are not working try the code search procedure(scans and transmits all codes one at a time)you will have to turn your TV on to continue with this procedure. If you don't have a users manual you can download one from rca.com/accessories/universalremotes. You can also try the codes listed for LG, they could work.
Mar 10, 2010 | RCA RCU300WBL Remote Control
My tv is locked
They have an internal battery for transport between rooms so as not to lose any pre-programed channels or info while unplugged. So to beat this you will have to unplug it for a few days and let it clear its memory. Mine needed almost a week but when its turned on after the right amount of time it will ask to do a channel search. So make sure you have it hooked up to cable before running that search or you will have to repeat the previous steps. Hope this helps.
Dec 13, 2008 | Zenith C27A24T 27" TV
Zenith zn620 universal remote
This may be of help for Zenith codes:
http://www.thompsontv.com/zcodes.html
Jul 20, 2008 | Zenith ZN620 Remote Control
Zenith Concierge H25W35DT 27"
The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
Mar 09, 2008 | Zenith C27A24T 27" TV
Locked channel
You might try 7777 for pasword reset on remote
Nov 02, 2007 | Zenith C32V37 32" TV
Zenith zn110
1. hold in "code search" till light stays on
2. press channel up until tv changes channel
3. press enter as soon as channel changes
note: if you pass  the  right code just use channel down to get back to it
Oct 21, 2007 | Zenith ZN110 Remote Control
Cannot fnd channels on my zenith tv
check to see if your t.v. is connected to your cable if it is connected properly and you are sure that every thing is connected .call a tech to repair the t.v. the problem could be in the tuner or IF circuit.good luck.
May 06, 2007 | Zenith ZN-501S Remote Control
Televison & Video Logo
353 people viewed this question
Top Televison & Video Experts
