Question about Krups Bravo 871 Espresso Machine
Incomplete machine The tool in which coffee is packed and is then attached to the machine is nowhere to be found
  • 13 Answers
Tip
BURNZY.....YOU ARE A GOD SEND!! After calling the Keurig Service Center about my...
Symptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump. This happened to my brewer two days ago. I have had this unit for about four years and never had a problem. When I called tech support at Keurig they said "it sounds like the pump is shot", but there was nothing they could do and they would not repair it. Instead of the throwing out my $300 coffee maker I figured I would try to fix it myself. After 3 hours of tinkering, I found and fixed the problem, so I am passing on the tip. Since 2.5 of those hours were spent diagnosing the problem, the fix itself is pretty simple. The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it. Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work. Hope this was helpful. Erik
on Dec 13, 2007 | Keurig B100 Coffee Maker
Where would i find an electrical cord for my West bend coffee maker?
First, I'm NOT a West Blend tech. But I've worked on similar brewers.
*** Call your vendor or service provider, especially if the equipment is on loan. ***
* Most table top coffee brewers (banquets) use the same cord (unless your in Europe). You will find that many brands have the matching cords. Check with your vendor for a replacement.
* You should be able to locate a plug at your local appliance store, MFR outlet dealer, and Amazon.
* These plugs are commonly found in places like Mom+Pop stores, Wal-Mart, or your local Thrift store.
* These cords usually have a bakelite plastic connector which will burn if attached to brewer when the plug was soaking in wash water or run though the dish washer. Replace any plug/cord that smells burning plastic or has a crumbly appearance.
Aloha, ukboy57
PS; in case you need a bunch, I found this on line;
https://www.walmart.com/ip/West-Bend-Coffee-Urn-Percolator-Urn-Power-Cord-Replaces-P193-74-6-Pack/409786702?wmlspartner=wlpa&selectedSellerId=5278&adid=22222222222066917243&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=c&wl3=17607384762&wl4=pla-1105773100946&wl12=409786702_10000005336&wl14=West%20bend%20coffee%20appliance%20cord&veh=sem
Feb 11, 2018 | West Bend Coffee Makers & Espresso...
What to do about a leaking handle on a farberware coffee pot?
if the handle is screwed on, remove the handles and place a fibre washer under the handle on the outside.
fiber washers ( carburetor washers) are available in assorted packs from a auto parts shop or quality tool shop
Jan 15, 2017 | Farberware Coffee Makers & Espresso...
How to replace thermoblock sensor?
To replace this part you will have to open the jura machine. I found this information out because I had the dreaded error 8 reading on my jura machine which stopped it from making coffee. To disassemble the jura coffee machine you'll need some special tools that I will talk about as I describe how to get to the sensor, make sure you get those tools or something similar.
The problem that you are having is the boiler is not heating properly (heating the water properly), so the taste of espresso will not be good. You need a high heating temperature to get good tasting espresso. This generally happens because the thermo sensor went bad and the electronic board is not sensing the proper heat because the thermo sensor went out.
1. Remove the drip tray
2. Remove the water tank
3. Remove the coffee cover and bean hopper cover (aroma cover)
4. Remove the cover for the pre-ground coffee shut
5. Now you will need to remove the cup warning plate that is stainless steel, it is fastened with 2 security screws. You'll need a Newelectronx t15 torx security screwdriver to take them out.
6. Now remove the top plate, there will be 5 screws fastening it down. Again use the Newelectronx t15 torx screwdriver to take them out. Pull it up to release.
7. On the rear end of the machine, you'll need to remove some weird oval head screws. The only place I could find the tool for this oval head screw was in the Newelectronx Coffee Tool Kit Set. Get the oval tool, which is different from the Newelectronx t15 torx bit and remove the next few screws. There are 2 screws - oval head, on the lower backside. Take off the rear back panel. On the left you'll find the mechanical parts.
8. On the boiler, which is the big metal part that is formed like an upside down tear drop. The thermo sensor is attached to the boiler with a screw - again use the Newelectronx security screwdriver to remove the security screw.
9. The thermo sensor connects to the electronic board. Detach the wire from the electronic board. Now the thermo sensor is off.
10. Replace the thermo sensor with a new jura thermo sensor that has the same wire colors. If the wire color is wrong the contact thermo sensor might not perform as it should.
11. Now put the machine back together. Good luck
Mar 25, 2015 | Jura Capresso Impressa S9 Coffee...
Have had my Bunn Home Coffee Maker for 2 years and it's worked like a charm! Unfortunately it has decided to go retire with no warning whatsoever :-( It just out of nowhere stopped working all...
Tools needed to dignose
An screw driver and an AC electric tester.
STEPS
open the pannel and chek the voltake is comming into the machine first.
reply me after that
thanks
Feb 09, 2011 | Bunn 10 Cup Home Coffee Brewer
I need a replacement filter for my kenmore coffee maker item#69768
If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Krups Bravo 871 Espresso Machine Logo
96 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
