My 20" Samsung LCD Monitor switches on and immediately off
My 20" Samsung LCD Monitor switches on and immediately off. It stays on for a split second and then goes off.
Please help.
Thanks
Thaabit
  • Thaabit Feb 29, 2008
    How does one fix the inverter board of Samsung 20" 204T LCD monitor?
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it goes off, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 29, 2008
  • 81 Answers
The spring tention of the switch is bad so u need to replaced...
Posted on Feb 28, 2008
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
My Samsung syncmaster 2220WM will not stay on. It
The picture board on your monitor has been malfunctioning for quite the period but you did not notice it, since the screen goes blank, it means the picture board of your monitor has developed fault and will need to be replaced.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Samsung 931B Monitor Screen will not stay
jane657, Hi there. Will you stop pushing the On/Off button on your lcd/fpd. It's Broke. Period. End. Finito!!! You will not fix it. However there is one test that you should do to determine hoe bad the problem is. You will need to reconnect the 931B to a known good pc that has been fully booted and has the WIN-DESKTOP or IE fixya web page showing. quickly connect the931B to the wall outlet and the PC. Turn on the monitor!!! Yes, I know it will only come on for a second..After the screen goes to BLACK, Shine a bright flashlight onto the screen at different angles, 1-2 inches from the screen. Let me know if you see something even though the screen is black. Anyway here are your options as a consumer/user. 1. Check if unit is under warranty. 2. Check withh Samsung to see if they have a SWAPOUT program. You send them your monitor+$40-$90 and they return a refurbished same model to you with a 30 day warranty. 3. Trade in for new monitor. 4. Check with local TV/Monitor repair guy who knows all there is to know about cold-cathode-fluorescent-tubes, their power-source(inverter type) and lcd monitor power supplys (SMPS) 5. Repair on your own. Not recommended for amatures with no solid state troubleshooting skills and no instrumentation for support. Bye for now. I'm louie12fix on fixya or lmistyrel@ aim.com
May 14, 2009 | Samsung SyncMaster 931BF LCD Monitor
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
SyncMaster 712N monitor problem
I've had a similar problem. I took apart the monitor (it was out of warranty by that time anyway) and found the lamps would not stay on. They'd flash for a split second before remaining unlit. I tried hooking up another LCD monitor's lamp to the Samsung, and even though I knew the other lamps worked fine, they exhibited the same behavior. Looks like something's wrong with the circuitry. The LCD actually does display the desktop on screen correctly. It's just the lamps refusing to stay on.
Sep 03, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Computers & Internet Logo
672 people viewed this question
Alun Cox
David Payne
David Payne
