Question about Gateway GT4022 PC Desktop
My computer will not power up but the LED on the MB's lite up.
I just build a computer two weeks ago and I try to add another HD but after add that HD and removed. Now my computer does not power up, even the power switch is dead, but the LED of the MB still lite up. Please help
    Problem Solver:
  • 6 Answers
I think that case is m/b crash. so u do first remove all power connector in your m/b and in later 3 minutes u can put all power connector in your board. All connected in ur board so u run your system firstly hear " te ", That is clear for your problem. But
u don't hear press key in checking ur screen in m/b BIOS setup key. i cann't tell exactly because BIOS setup is many different but any configure u can do that for example: LOAD SYSTEM FIALD or System Performance...
Ok i wish u do that and slove your problem...
Bye
Posted on Apr 01, 2008
    Genius:
  • 3,587 Answers
Hmmm..not too cool..open up the system, and remove the power connections from all but the system board, and see how that goes..no drives..just m/b and memory..
Posted on Feb 27, 2008
I have motherboard Compaq #277498-001 and can't find power sw
Not sure of your particular MB, but most always the switch is a pair of pins in an array where the front panel LEDs and reset and power switch are.
This array of pins is almost always at the lower right hand side of MB. Assume the components side is facing you and the expansion slots are at your left hand, (where you add extra cards like video etc). then look at the lower right side or bottom edge, mostly right at the edge of the board. Should be an a double row of pins, at least 8 maybe up to 12. Look real close next to these and you may see print indicating which pair do what. PS = power switch. RS = reset, HD = Hard drive LED PLED = power led light.Spk internal beep speaker etc. (Note LEDs require correct polarity to work) Sometimes no print there.. Then you need the manual to decipher pin pairs. Or experiment. All you need to do is make the connection momentarily (like push button) with a small screw driver tip to start it, while looking for correct pins.
If no power on check your power supply connections on the MB. Or suspect either MB or Power supply issue.
Mar 24, 2012 | Compaq ( 277498-001) Motherboard
Dell GX OS Name Microsoft Windows XP
If the power light is steady amber — The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the microprocessor power cable is securely connected to the system board.
Its a cable that has socket named P2..
Thanks for using fixya
Proton
Nov 09, 2009 | Dell GX260/270 PC Desktop
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
Hellow, I 'm in problem with my computer .I have an old configuration computer AMD- 2200+-ASUS- a7v400mx. When I? was working with it suddenly my monitor gone blank, M. board LED and HD LED become...
It seems to me that your motherboard may be on it's way out. Those seem like some of the signs when the MB is in it's death throes.
Or make sure your system isn't dusty or in a moist area. Could be your power supply isn't high enough.
I'm going with motherboard though.
Jul 08, 2009 | Computers & Internet
T2682 emachine running fine video lite went yellow & HD also
The first thing you should do is remove the video card and try to boot the PC using the onboard video (video on the Motherboard) and see if that solves the problem. If it does, try putting the video card back in in a DIFFERENT PCI slot and try it again. Sometimes Windows loses its marbles about cards inserted into PCI slots. My nieces eMachine loses its marbles over the Wireless LAN card about once a year, so I just move it to a different slot (swap it with the phone modem card). If that makes it flaky again, try updating the video card drivers. If it doesn't help, your video card is shot.
If it isn't the video card, try taking out one memory chip at a time and booting with the first one in. If that doesn't do it, swap the memory chip with the other one and try booting it again. If needed, replace bad chips....
After that, it is probably the power supply or the MB itself. Swap out the power supply first. If it is not the power supply, then it is probably the MB, and you are SOL.
May 10, 2009 | E-Machines T2682 PC Desktop
Is my P4P800s-x fried?
Yes, You need to Replace the Card for this.
Jan 12, 2009 | ASUS P4P800S-X (610839118175) Motherboard
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
HD LED and POWER LED Connection
here is a link to the manual that should give you a diagram - http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4bgl-mx/e1339_p4bgl-mx.pdf - hope this solves your problem.
Sep 17, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Gateway GT4022 PC Desktop Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
