Question about Kenmore 22812 Bagged Canister Vacuum
Kenmore canister vac model 116. 2641381
Have noticed like small blue sparks coming from inside the motor
  • 833 Answers
Small sparks coming from the brushes is normal. That would be a thin line of sparking near the commutator/brush interaction point. Large or irregular sparks are different. The commutator (segmented copper item) should be fairly bright copper color. If not, the dirt on it could cause problems. The right way to clean it up is to use automotive brake cleaner and a rag or light sandpaper followed by the cleaner and a rag. Wipe off the contact sections of the brushes and replace them exactly the same way. Still got the issue? Get the unit serviced.
Posted on Feb 28, 2008
  • 55 Answers
Sounds like motor brushes may be going. Is the vacuum cleaner old? I suggest bringing the unit in for service to replace the motor brushes. Get a quote to see if is worthwhile to fix.
Need motor brushes for kenmore vacuum
Chances are the part has been discontinued. You might want to check for a replacement motor. Sometimes panasonic may have something compatible. Good luck
Aug 30, 2015 | Kenmore Vacuums
Kenmore vacuum model 116
Anthony, glad to have you back, except that you're missing a bunch of numbers. All Kenmore vac's models start with a 116., (notice the decimal after the 6). Then there's at least four to six more numbers that spell out the actual model. If you can get those for me I might be able to help.
Oct 22, 2013 | Vacuums
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
Sparks and smoke
you either have something worn out or the motor inside is going bad. Sounds like the motor in the power head is going bad. Disconnect the the wand from the power head and flip over the head take the plate off. then take the plastic cover off uou should get to the motor then. look at all the parts. I would think you need to replace the brush roll, belt and motor. But this is just a guess
Jun 26, 2008 | Filter Queen Majestic Canister Vacuum
Kenmore Central Vacuum System-electrical o.k. but suction function not working. No noise from canister.
There should be a switch on the canister, for manual or automatic. Switch it to manual and see if it comes on. If it does, then there maybe a bad relay. If it doesn't, then there is a problem inside of it, motor, pc board, would have to be checked. Without the model number, not sure what components are inside without the model number to look it up.
Feb 25, 2008 | Vacuums
Kenmore 22812 Bagged Canister Vacuum Logo
196 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
