Question about Samsung Digimax A400 Digital Camera
Shutter does not open
Camera worked well untill recently when shutter does not open on power up. Batteries are fully charged and shutter feels unrestricted when gently moved manually. Local repair shop wants to charge excess of R900.00 to repair so would appreciate any assistance.
  • 1 more comment
  • Anonymous Sep 22, 2008
    it just wont open it's making a noise its trying to open but it wont open it
  • BOBTEE Dec 28, 2008
    My samsung digimax a400 switches off imediately wen i switch it on. The lens is not extending. Wot could the problem be?
  • Anonymous Mar 16, 2014
    Battery fully charged but shutter will not open
The camera does not gets opened on power on it seems that some gear has broken inside
Posted on Sep 22, 2008
  • suraj1 Sep 22, 2008
    no the lens does not get adjusted when power on
    my lens got struck and camera does not functioning
Its not software or moter problum this is only sticky shutters, so u clean properly with pepar
Posted on Feb 28, 2008
  • 68 Answers
Does the lens extend upon powering on? Or is the whole motor mechanism not turning on.
Since the shutter does not feel restricted, possibly the slider is broken, which means the camera does need to be opened and repaired. You could try manually holding the shutter open while turning the unit on to see if it is a software fault that may be overridden.
If the lens is not extending upon power on though, thats a different story.
I have a nikon N2000 35mm slr, before it was fully functional, now the problem is, The shutter won't open/close but the rest of the camera controls are still functional. Camera wasn't set on B...
So I assume you have changed the batteries and made sure there isn't any corrosion on the contacts. If your mirror is flipping up but no shutter, it sounds like a bad shutter. Check the shutter from the back, then from the front behind the mirror. Look for abnormalities or residue. It is a great camera and uses standard batteries (!) but the 1/2000 shutter has a half life like any other SLR. If you are going to throw it out you may want to open the back and use a q-tip to drip a couple drops of 90% alcohol on the top and bottom (and sides) of the shutter. As a last ditch, I throw cameras or lenses in the toaster oven at 200° for 10 min. and retry (take out batteries and film). At the least it will kill any fungus at the worst it hardens some lubricants. It does make you feel like you are doing some specilized scientific work before you toss it in the trash.
Jan 07, 2018 | Nikon N2000 35mm SLR Camera
As soon as I turn it on, it shuts back off
Kodak offered no help with this problem and for my camera more than five years old no repair option was available. However, after thinking about this problem a solution was found. Perfectly charged old batteries and new batteries fully charged did not correct the problem. Here is what worked for me: With fully charged battery installed, place closed camera on EasyShare-One camera dock. With the the green light flashing, simultaneously depress both the power on/off button and the shutter button. With both these buttons held down, toggle the capture view switch from an intial down position to up, and then down position.Now release both the power on/off button and the shutter button simultaneously. This whole process takes about 20 seconds. Let the camera remain on the dock until the green light stops flashing. Remove the camera from the dock, open the camera back as usual and the screen will present you with date/time setup. Enter the date and time as required, hit the 'done' icon with the camera pen and the camera will now function normally. Why this works is speculative. However, the idea behind this method is to force a 'reboot' to factory settings by maximising conflicting electronic input signals.
Dr Barry T Rubin
Aug 13, 2010 | Kodak EasyShare One Digital Camera
Can't take a picture
shutter failure due to failure of power supply to the shutter/sticky blades
Feb 28, 2010 | Kodak EASYSHARE M1063 Digital Camera
The lens "shutter/cover" doesn't open
Please try the following: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 25, 2010 | Kodak EasyShare C875 Digital Camera
When turning camera on the shutter opens then shuts straight away and switches off
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 11, 2010 | Kodak EasyShare M863 Digital Camera
I push the power button, there is a sound like shutter is opening then three beeps. Shutter doesn't open
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 28, 2009 | Cameras
Camera wont turn on
This problem is frequently due to either weak/defective batteries or corroded battery terminals inside the camera. Make sure that you have fresh/fully charged batteries in the camera. If the problem persists, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Aug 12, 2009 | Olympus FE-370 Digital Camera
Camera shuts off after one shot
Set the camera to clean ccd mode and carefully remove the lens. If you can't see the ccd but only the shutter then the shutter is sticking. I have this problem when not using the camera regularly. My solution to free the shutter was just to set the camera to long exposure and just keep restarting the camera and taking a photo until the shutter moves. This problem happened from the very first time I had the camera run low on batteries at a few months old but at the time I never checked the shutter and the camera just restarted once and it worked.
Sep 05, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Samsung Digimax A400 Digital Camera Logo
358 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
