EXCEL macro Hi, i need help for the following: I know how to disable rightclick on the worksheet but not with pictures... i hope somebody can help mw with this... please tell me how will i disable the right click fot shapes and pictures... any help is greatly appreciated :) thank you so much
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Hi ann, looks like your answer is most likely to be found here:
http://www.vbforums.com/showthread.php?t=305203
Found this by Googling: excel disable right-click on picture
Posted on Feb 28, 2008
How to delete a header/footer in excel 2010?
To remove the header or footer text from Excel 2010 worksheet, you can follow the instructions below:
1.Go to "Insert" tab and then go to "Text" section.
2.Click "Header and Footer"
3.Click the left, center, or right header or footer text box at the top or the bottom of your worksheet page.
(Note: Clicking any text box selects the header or footer and displays the "Header and Footer Tools", adding the "Design" tab.)
4.Press "Backspace" or "Delete" on your keyboard.
To know more about removing header and footer, you can refer to "Remove the header or footer text from a worksheet" section on the following Microsoft support page:
http://office.microsoft.com/en-in/excel-help/use-headers-and-footers-in-worksheet-printouts-HP010342991.aspx#BMremoveheaderfootertext
Hope this will help you.
GuruAid.com
Sep 03, 2014 | Microsoft Computers & Internet
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
Hello, I have got a problem in excel and thought some expert here can solve it. I have a worksheet with thousands of rows, in following format 1:00:00 1:59:00 30/12/2009 3:00:00 3:59:00 30/12/2009...
There are two ways to solve it, with a macro and without.
In either way, the concept is to determine the difference between rows, if it is more than 1 hour, then you have detected the missing row.
With a formula, you can tell excel to put true if it is the case and correct it manually.
For a macro, basically you detect the same thing and then insert a line with all the appropiate information. I can write the code for you, but i would prefer to have the sheet. You can send me the information to my mail lucho_lnc@yahoo.com
Mar 03, 2010 | Microsoft Excel for PC
What do you mean excel macro
is a hiden process of Excel, is like program or several steps ( like moving cursor, make calculations, moving files, is no limit what can do, but normaly is not visible, is low level programing is always used for virus spreeding.
Jan 14, 2010 | Computers & Internet
I need to import data from access into excel where one column go into one worksheet and other into next worksheet
Acess will only export the data into an Excel spreadsheet with each element of the record going into a sperate column.
You can record macros to get the data to go where you want it to go on the spreadsheet.
Jun 10, 2008 | Microsoft Office Access 2003 (077-02871)...
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Attendance sheet in Excel
Hi KDina,
If you need me to work on this project for you please contact me at hdbas8@gmail.com
May 17, 2008 | Excel (SS8SATAS5128400R)
Macro
Hi motilal
Follow these steps to create multiple macros
Click the Microsoft Office Button , and then click Excel Options.
In the Popular category, under Top options for working with Excel, select the Show Developer tab in the Ribbon check box, and then click OK.
Note The Ribbon is a component of the Microsoft Office Fluent user interface.
To set the security level temporarily to enable all macros, do the following: On the Developer tab, in the Code group, click Macro Security.
In the Macros Settings category, under Macro Settings, click Enable all macros (not recommended, potentially dangerous code can run), and then click OK.
Note To help prevent potentially dangerous code from running, we recommend that you return to any of the settings that disable all macros after you finish working with macros.
Open the workbook that contains the module that you want to copy and the workbook that you want to copy the module to.
On the Developer tab, in the Code group, click Visual Basic.
On the View menu, click Project Explorer .
Drag the module that you want to copy to the destination workbook.
Regards,
TheAssembler
May 06, 2008 | Microsoft Excel for PC
Microsoft Works Please help
Get new stuff you don't have to look through particularly grotty Half-Price Books (though you could use AbeBooks) to obtain relevant manuals! Linux and OpenOffice can do your job; OpenSolaris and one of Sun's office suites can too. Your machine won't be zombified every time you hit the internet with it this way, too.
Works and Excel differed in several editions. You might not be able to just rightclick on the tab and ask select New Worksheet or Edit/Insert/Worksheet.
Mar 20, 2008 | Microsoft Windows 95 NT 4.0 Workstation
Computers & Internet Logo
50 people viewed this question
Alun Cox
David Payne
David Payne
