Question about E-Machines eMachines Desktop PC
Desktop not coming
Sir,
My icons on the desktop r not coming.ever after restarting the system several times.what to do?
    Guru:
  • 1,463 Answers
Hi you could try this see if works for you
  1. Click Start | Control Panel.
  2. Double-click Display. Click the Desktop tab.
  3. Click the Customize Desktop button.
  4. On the Desktop Items window, General tab, click the check boxes next to the desktop icons you want to show, such as My Documents, My Computer, and so forth. When you are done,
  5. click OK.
riz.
Posted on Feb 27, 2008
The icons wont come up
Problems with desktop shortcuts and icons
Shortcuts on the desktop do not work or are broken
Desktop icons are broken or have not been used in 3 months
Startup items do not work or are broken
System maintenance tasks
Free up disk space by repairing disk volume errors such as bad sectors, lost clusters, cross-linked files and directory errors click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
Free up disk space by removing error reports and troubleshooting history older than 1 month
Set the correct system time and synchronize system clock with the time server
You receive the following errors:
Windows update error 0x80072F8F
the item that this shortcut refers to has been deleted
hope this helps
Jul 05, 2012 | Computers & Internet
A simple free program that can hide/restore icons on my desktop
Hi hugh hinds....
Try this easy solution to your problem
Please take time to rate me
Hiding Desktop Icons in Windows XPWith a good choice of wallpaper, your computer desktop can add an attractive, even artistic, element to your home or office. Eye-catching desktop wallpaper can be as decorative in its way as a painting or other wall hanging.
If you value the aesthetic potential of your desktop, you might like to enhance it even further by hiding the desktop icons.
Hiding or showing your desktop icons in Windows XP is a simple, two-click procedure.
To hide desktop icons:
  1. Right-click on the desktop and open the "Arrange Icons By" sub-menu.
  2. In the sub-menu, click "Show Desktop Icons" to uncheck it.
The icons should disappear to leave a clean, uncluttered desktop. To show desktop icons again, repeat the above procedure. When the icons are hidden, clicking on "Show Desktop Icons" will enable the option and the icons will reappear.
1...Right-click on the desktop and open the "Arrange Icons By" sub-menu.
2...In the sub-menu, click "Show Desktop Icons" to uncheck it.
Aug 23, 2011 | Computers & Internet
My acer desktop has been hanging all of a sudden. When i restart the desktop,it takes about an hour for it to reach the home screen and another hour for the home screen to load. When i try clicking on the...
the hard disk on your pc is almost worn out.
you will need new hard disk. Install fresh copy of operating system and loading to home screen will be normal again.
Jan 09, 2011 | Acer AX3950-B3062 Desktop with P206H...
Start up and desktop icons missing
This could happen due to various reasons like :
1. Any recent update done.
2) Virus infected
3) Windows missing/corrupted files.
There are several steps to resolve the issue.
Try one after another and check if that fixes the issue.
Step 1
Try this Fix
Click on the Download link and install the Fix No. 195 ( Restore Desktop Icons and Taskbar )
Download Link
Step 2
Press CTRL-ALT-DEL to bring Task Manager.
Click on New Task and type appwiz.cpl and click OK
This will re-run add/remove programs.
Remove/Uninstall all new program you installed before having this problem, Also remove the Windows XP Hotfix
Restart your PC.
The access to the taskbar , icons will all come back and Install a new Antivirus.
Step 3
If None of the above steps work, try a System Restore to previous date
Click START - All Programs - ACCSESSORIES - System Tool - System Restore
Choose the date before the system started giving trouble. ( The Date will be in bold ( highlighted ) which indicates the system can be restored to that date with all the settings on that date )
*Note : Doing system restore will uninstall any software/program you have installed from the date you choose the system restore till current date, However it will not delete any files created )
Hope this is helpful.
Nov 10, 2010 | Dell Dimension 9200 PC Desktop
Hi, am trying to look for specific obstacles and incompatibilities that may arise in a multivendor networkign environment by illustration.
sir
I install xp2, it works for days in third day icons are disappeared and mmouse working properly but right and left click are not working
system is automatically gets restarts
Feb 02, 2009 | Gateway Essential 400 PC Desktop
AVG will no install error 0x800736b1 also retrirve my desktop
Hi there. My name is Alex and Im here to help solve your problem
First of all, AVG has always had a problem installing when windows updates are enabled and download and install automatically. I would recommend uninstalling all updates that have been installed to your computer and disable automatic updates which I will explain to you below
To uninstall the updates.
Click start, settings and click control panel.
On the icon add and remove programs, please double click
You will now see all the programs and updates installed on your computer. The microsoft updates are located near to the bottom of the list and there may be a lot of them installed. You can only uninstall one update at a time. You may be prompted that uninstalling a windows update may cause a program not to work properly, this is normal so you can continue uninstalling them. When you have uninstalled these updates please restart your computer.
To disable the automatic updates
Right click on your icon My computer or My pc which is located on the desktop or on the start menu (if you are running windows xp) and select properties
You will then see a sub menu called 'Automatic updates' and inside this menu you will have the choice to disable the updates
If you are using windows xp and you have system restore enabled on your computer, then you will be able to take the computer back to an earlier time when it was working correctly. Please save all documents first to insure that nothing will be lost if you decide to do a 'system restore'. There is a very friendly wizard to help you restore your computer. You can get to the system restore by clicking start, programs, accesories, system tools and selecting system restore.
Regarding your problem about your desktop disappearing, to restore your icons on the desktop, right click anywhere on the desktop and select organise icons and be sure that the heading 'show desktop icons' is ticked. This will restore your desktop items
Last of all try installing AVG, if you still experience problems with this issue, then please let me know. Im happy to help
Oct 10, 2008 | Computers & Internet
Desktop is blank
Shut your off. Wait 30 seconds. Boot the computer up into safe mode by pressing f8 before the Windows screen appears. Select Safe Mode and press enter. Once the desktop appears, restart your computer the normal way.
If it continues you should reinstall your operating system to fix the problem.
Aug 02, 2008 | Microsoft Windows 98 for PC
XP Pro Problm
can you explain the problem more? what do you mean vanished? does the screen fade out to white or black, or there is a blue screen with white text, or does it restart the whole system?
Mar 05, 2008 | Microsoft Windows XP Professional With...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
