Question about Canon PC-940 Black and White Copier
CANON IR2016 i HAVE MULTIPLE ERRORS IN MY IR 2016 COPIER LIKE E007,E001,E808,PAPER JAM OPEN LEFT COVER WHEN TRY TO USE DRAWER CAN'T LIFT THE PAPER FROM DRAWER ETC
  • 7 more comments
  • Anonymous Apr 07, 2008
    DEAR SIR
    This Sudhir Ihave Problem in Cannon Ir 2016
    thy show that System Error in E808
    can you give me Ans.
    Ihave open the left side & remove the Paper
  • gyamfison May 19, 2008
    my canon iR2016 gives an error of E808.when receive this message the machine do not work.please assit me with guidlines to reset the machine.
  • Hafed Albaskari Jun 15, 2008
    I have in may copy machine Canon IR2016 Error ( system Error E007 )
  • moloyraj Nov 14, 2008
    here is canon ir2016 copier here is a same problem.
  • Anonymous Mar 12, 2014
    Reset error e007 ir2016
  • Anonymous Mar 23, 2014
    i cant get the printer driver for my canon ir2020 copier. am using widows xp
  • Anonymous Mar 28, 2014
    lot of paper jam in the left side of iR 1024 cannon copier
    paper jam in the left side of canon iR1024 copier
  • 109 Answers
You have a problems in fixing unit maybe in the fixing film or in the fixing drive
Posted on Oct 28, 2011
  • 28 Answers
Hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Posted on Feb 28, 2008
  • 4 Answers
E808 Fixing Assembly have trouble - You try to test jack connect to Fixing Unit & the Heater & Fixing Motor. If all is good, you must to change another "DC Board" & "Power Supply".
Posted on Apr 16, 2008
2 Suggested Answers
spinal
  • 287 Answers
SOURCE: canon copier iR2016
Hello iali307. All three error codes have to do with with an item called the fuser. This component, when working properly, is designed to provide extreme heat (to melt the powdered toner) and pressure (to force the melted toner onto the paper and"fuse" or bond the image to the paper. All manufacturers of all copiers make sure that this system (common to all) is intensely monitored as a building burrning down is not a maketing tool. Your copier's "fuser" can be rebuilt, but I would strongly advise the entire unit be replaced. My company (thet are tight assed) realizes the cost /benefit analysis of trying to rebuild these fusers and opts for replacing the unit. The part # is FM2-3345-000 if you live in a standard 120 v part of the world. I hope this helps,I wish you the best. :-) .......................SPINAL
Posted on Mar 04, 2008
How can i fix paper jam, close left cover or drawer cover ir 2016 canon
hi . be sure there is no paper jam inside the machine . turn off and on if problem persist maybe some of the flag sensors maybe stuck.
Mar 23, 2016 | Canon iR 2016i Black and White Copier
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Jul 16, 2010 | Canon Office Equipment & Supplies
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
System error E007 IR2016 photo copier
i think the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. Good luck sir let us know how you make out.
May 18, 2010 | Computers & Internet
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E540 0001 Paper surface not detected (standard tray)
E542 0001 Paper surface not detected (optional tray)
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
Canon copier iR2016
My Canon copier IR2016 Problem code E007 Solve the problem pls
help me
Mar 02, 2008 | Office Equipment & Supplies
Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
Canon PC-940 Black and White Copier Logo
1,335 people viewed this question
old marine
old marine
