Question about Linksys Wireless-G WRT54GX Router (WRT54GX2)
Unstable PS3 connection
Hi, i need some help. Using a Linksys WRT54GX + Siemens Speedtouch modem combo to hook up my PS3 to the network. Keep getting a NAT3 connection, so i assigned a static IP to my ps3 and set it to DMZ. Media server disabled, UPnP disabled, but it still doesn't work. HELP PLEASE!!!
Just a question, if i disable UPnP on router, will it kill the internet connection on other PCs at home? Coz my family uses the same router as well, with wireless connection. Totally lost with all this networking knowledge.
  • 1 more comment
  • zeroXII Feb 27, 2008
    Tried that before i did the DMZ. Doesn't seem to work. Alot of people using the same router seem to imply that the UPnP disabling helps. Not sure how though. Should i keep it disabled on my ps3 or enable it?
    I also read somewhere else to adjust the MTU to 1365. Also no clue on what this does.
    Anybody using also Linksys WRT54GX with their PS3 managed to get a NAT2 connection? If so, please tell me exactly what settings you input, coz i'm at my wits end out here.
  • zeroXII Feb 28, 2008
    here are the settings i used on my PS3:
    IP - 192.168.1.200 (outside DHCP range)
    Subnet mask - 255.255.255.0
    Router IP - 192.168.1.1
    DNS - 192.168.254.254 (checked with ipconfig/all)
    UPnP - disabled (router enabled)
    Media Server - disabled
    Fowarded ports to the set IP. Still getting a NAT3 connection. Howeve, i didn't get disconnected even once last night. Not sure how it'll last. Everytime i try to play Rockband online, i keep getting DCed.
    So i input the same ip for DNS as the router? Ok will try that tonight.
    Any other settings i should be aware of on the router side? Should UPnP be enabled if i foward ports? As for the firewall, i tried disabling that as well before. Doesn't seem to have any impact far as i can tell. I'll try it again with the new settings. Problem is i don't use the WEP so no firewall kinda sounds risky.
    Novelist:
    Scholar:
  • 136 Answers
Good idea to assign your own ip but no need to use dmz...
do the following:
1. reset your router to factory settings, assign urself an ip address (make sure its out of the scope of the dhcp), no need for dmz
2. enable upnp (thats what ps3 uses)
open these specific ports if u are using firewalls
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
also if u want to make it faster use Port forwarding and then forward the above port to your static ps3 ip address and u will get even lower pings to play games and no lag
cheers
smeags
Posted on Feb 27, 2008
  • Tristan B
    Tristan B Feb 27, 2008
    Try turning off the router firewall to see if it is the problem. I think when you start playing with MTU you are over complicating the problem.
    Also if you are assigning your own ip address, make sure you have done that properly ie...your router would be 192.168.0.1
    therefore ur manual ip address should be 192.168.0.xx where xx is outside ur scope use 100
    but you need to put in the subnet mask ie 255.255.255.0 and the gateway and the dns needs to be your router ip address ie 192.168.0.1
    let me know how you go.
  • Tristan B
    Tristan B Feb 28, 2008
    Your DNS looks all screwed, use 192.168.1.1 and let your router determine the best dns to use. Most ISP have a few DNS servers for load balancing so i suggest you do that rather than specifying your own dns on the ps3.
    good luck
    smeags.
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 | Cell Phones
My nat type on my Playstation 3 is nat type 3 (strict). I would like to know what setting configuration on my WRT54GX router so that the nat type decreases.
Well this becuse of NAT on the router
you can solve the problem by putting your PS3's IP address on DMZ in the router
access your router page (type 192.168.1.1 in the address bar of internet explorer)
username would be admin and password would also be admin
go to the DMZ and enter the IP address of the PS3 there after enabling it....restart your PS3....bingo your problem solved
Note:- you can check your PS3 IP address in the network settings and connections option on PS3
Hope it helps
Thanks
Jan 16, 2011 | Linksys Wireless-G WRT54GX Router...
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
I was given a linksys wireless-g model wrk54g router but it didn't come with an installation disk. I have a Thomson speedtouch modem ST530 V6. Right now I am hooked up thru ethernet and getting internet...
was the router used by previous users? or did you buy it? if it was used then it was probably configured for different ISP. You don't need any CD. Just connect to the router via your browser (probably http://192.168.1.1) and adjust settings in WAN section.
Mar 15, 2009 | Linksys Wireless-G Broadband Router
Wireless Networking With a Linksys Wireless-G WRT54GX Router?
k2rt9ceswg,
You seem rather savvy so I won't bore you with frivolous explanation. Essentially ISPs detect the MAC address of whatever device is plugged into their network. In the case of your laptop connected wired to your modem, the MAC address of your wired adapter is what is tied to your ISP account. When you plugged in a router, the MAC address of that router was different than your laptop's wired network adapter and your ISP said "nope, not letting that connect". This is something most ISPs are doing now-a-days.
You can get around this by following these steps:
  1. Plug your PC back into the modem wired
  2. Ensure you have internet connection again
  3. Go to Start -> run and type "cmd" without quotes
  4. Type "ipconfig /release" without the quotes (there is a space in there that needs to be in there)
  5. Disconnect your PC from the modem and plug the router into it
  6. Plug another LAN cable into the router and your laptop
  7. In the same command prompt, type "ipconfig /renew"
If the computer pulls an IP address for the wired ethernet, you should be all set to disconnect the cable from the router and PC and try to connect to it wireless. If it doesn't pull an IP address, you'll need to contact your ISP and inform them that you're having trouble getting your new router to work with your existing network.
You might also consider depressing the reset button located on the back of your Linksys router to set the router to its default configuration. This would clear all previous settings if there were any and might clear up any configuration options you had set when previously using this router.
Mar 03, 2009 | Linksys Wireless-G WRT54GX Router...
Setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
Feb 15, 2009 | Linksys Wireless-G WRT54GX Router...
Wireless
Whats the exact model # of the Speedtouch?
Well if your Modem doesn't have a WAN for a network cable (RJ-45) if all it has is a usb for connecting to a PC only I hope you have WindowsXP or Vista. Well what you can do is use your PC as a gateway like... What you would need to do is Plug the speedtouch into your PC with the usb... Plug the WAN from your router into your PC's network jack. Now you can go and do the Wireless/Network setup wizard and tell it your using a PC to connect other PC's to the net.
May 02, 2008 | 3Com OfficeConnect Router
Opening ports on 4100
Thanks for the information. I'd recommend obtaining a router, it would make your life easier because routers are made to do exactly what you're needing to do (split your internet connection among several devices (PS3, PC, etc.). I'm a fan of Linksys routers, I use them in every home deployment possible. You can find the Linksys WRT54G or some variant at any big box store (Best Buy, Circuit City, etc.) or at online retailers (NewEgg.com, Buy.com, Amazon.com) for real cheap. All you'll need to do is hook up your router to your ISP'd modem, hookup your PC & PS3 to your router, enabled uPNP (universal Plug & Play) on the router and you're set.
You could use your PC as a router (assuming your PC has two network cards in it). You just turn on Internet Connection Sharing (ICS) and specify which card is connected to the ISP's modem (internet) and which one is connected to the PS3 (internal network). I don't recommend this solution as it is a bit buggy and having to route all the data from PS3 through your PC degrades the online performance on both the PC & PS3.
I hope this info helps, let me know if there's anything else I can do to help.
Feb 01, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Linksys Wireless-G WRT54GX Router (WRT54GX2) Logo
1,254 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
