Question about Epson LX-300 Matrix Printer
Auto Tear off for Epson LX300+
When I use continuous paper with the push tractor, paper should advance the paper perforation to the tear-off position where I can easily tear off the printed page. When the printer receives data, it should automatically reverses the paper to the top-of-form position and starts printing only the data given for print and paper should stop at end of the print.
  • 10 more comments
  • Anonymous Jul 07, 2008
    YES
  • jigneshsheth Sep 01, 2008
    I am also suffering from this problem so if you get the solutions, please give me so i can solve it.
  • vivek_gosavi Sep 06, 2008
  • fransroodt Oct 15, 2008
    When im printing Quotations the printer prints 1 and stops in the middle of the second page.
    Please help.
  • a_sh04 Nov 28, 2008
    the continuos paper should reverse itself to the top position.
  • Anonymous Dec 12, 2008
    my printer epson lx300+II has a some problem. My paper is out and runaway from rolling paper. how can I solve this problem
  • saeed_sultan Feb 26, 2009
    printer prints all the help pages with holding auto tear off , but do,nt save the changes and returns to its previous settings
  • Anonymous Mar 29, 2009
  • Anonymous Mar 30, 2009
    same problem happening me
  • palani123 Mar 30, 2009
    I get same problem
  • Anonymous Apr 20, 2009
    I HAVE THE SAME PROBLEM
  • Anonymous Mar 29, 2014
    does not print. Warning: the paper cassette is not sett correctly. It looks like it is in the correct position
Friends
you have to get the exact page size of your continuous paper. then you go to start -> printer and faxis -> then go to file -> and server properties.then create one paper which is exact sixe of your paper. Then go to printer preferances and select that paper.
to switch on tear off refer manual.
Hope this can solve the problem.
Posted on Oct 27, 2008
    Genius:
  • 1,027 Answers
PAGE7- 9 of the users guide describes how to set it up.
http://files.support.epson.com/pdf/lx300_/lx300_pg.pdf
Posted on Mar 08, 2008
Epson 1150 printer on to printer all LED will be blicking
Posted on Jun 13, 2008
Need salution
Posted on Dec 02, 2008
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
What is the meaning of pitch in this printer andalso tear/off/bin means
Pitch is the size of the caharacters or the letters.Tear off is where the paper gets torn off by the perferation.It is used to push the paper up or down after printing to a position where the tear off guide meets the perforation.
Oct 29, 2012 | Epson LQ-2090 Matrix Printer
Pepar jam in printer
Follow these steps to clear paper jam: 1. Turn off the printer. The printer is off when powerswitch is pressed down. 2. Open the front cover or top cover, depending on thetractor you are using. 3. Tear off the fresh supply at the perforation. 4. Gently pull the paper out of the printer. Remove anyremaining pieces of paper. Hope this will help you.
Sep 14, 2011 | Epson FX 2170 Matrix Printer
How to set half half size paper
Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
Jun 25, 2009 | Epson LX-300+ II Matrix Printer
Configuration of page length
Most of these older printers use a special key to enter setup...usually upon power-up. Have paper inserted, because that is where it prints it's configuration.
It will probably use some of the feature buttons to change the paper size and tear-off options. Sorry I can't help with a manual, but I hope this helps.
B)
Apr 08, 2009 | Epson LX-300+ II Matrix Printer
Printing on the same line after a few pages printed
I first oiled the bar once more and while the printer was off, moved the head across the bar forcefully several times until it felt the ease to move. I then typed a document with numbers 1 to 10 each number typed two lines below the other and tried printing this document several times. This worked perfectly and the printer is now in order.
May 30, 2008 | Epson LX-300+ II Matrix Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Pause & ready led blink alternatly after initilize
Check if the paper type is set correctly (in thebackside right there is a lever to set continuos paper, or single sheets).
May 03, 2008 | Epson FX 1170 Matrix Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Feb 11, 2008 | Office Equipment & Supplies
Epson LX-300 Matrix Printer Logo
6,845 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
