Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
I have a hotpoint dishwaher and every time i put it on a wash it dont do anything, i can hear it trying to start but it dont, and after a few mins it puts itselth in a eco wash, but still dont wash.
  • 108 Answers
Please check the following.
water supply tap turned on?
water pressure supply sufficient, run your tap is it running normally or trickling?
Is the inlet hose kinked, check behind the unit?
Is the door closed properly?
Please dont forget to rate!
What model and how old is your unit?
Posted on Feb 27, 2008
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Oct 21, 2012 | Hotpoint Washing Machines
Hotpoint wd64 washer dryer. Clothes are not being washed after cycles. very evident on whites. Seems to be running through cycles quickly. put onto c cycle. long 95deg wash. takes in water and starts very...
Hi
You'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Sep 16, 2011 | Washing Machines
Can you help? we have a hotpoint aquirius 1100 waher, the drum seal seems to keep getting dirty, wife keeps machine spotless and allways cleans seal, but constantly gets brown scum going onto washing and...
hi my trick is .................... WHITE VINAGER ...YES VINAGER ... right get 5 ltrs of white not brown or your cloths will STINK :))) now wip some around seal .... tip 2 ltrs into drum ...and rest into powder capartment .... leave for 5 min ...then put on boil wash ...DONT PUT ANY THING ELS IN ..IE CLOTHS OR POWDER.. it normally gose .. wash through x2 times with powder ect b4 any cloths go in . bsc appliances bristol 07779933829 postal service too.
Feb 26, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
Apr 27, 2010 | Hotpoint Aquarius WD640 Front Load...
Brand new Hotpoint AQXXL 149 PI died a death after 10 mins!
This is joyce
Please do not try to work on anything that is new it will void your warranty, call your technician call where ever you bought it from and tell them you dont want this item its not working for you. usually they will replace or get you help quickly
thanks
joyce
Feb 07, 2009 | Washing Machines
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Sep 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
100 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
