Question about Koolatron (785169015699)
WONT RUN PLUG IT IN TURN IT ON THEGREEN START CLICKING & THE FANS ARE CLICKING ALSO.IT DOES NOT GET COLD. BRIAN DAVIS 2614 COUNTY ROAD 5700 LUBBOCK,TEXAS,79415 mopardavis@xanadoo.com
  • Anonymous Mar 21, 2008
    My koolatron is having the same problem, i plug it in and the green light starts flashing and making a clicking sound and the fan is not moving but making a clicking sound and seems to be struggling to move. i've tried unplugging it and plugging it back in and leaving it unplugged for a little bit but no result. the solution i read for this makes absolutely no sense to me. so can someone speak in laymans terms?
  • Anderson Farm
    Anderson Farm May 21, 2014
    found a way to force start the red version that does not take coins the blue botton when you press it it says serving keep on pressing the buttion like 20-30 times then you will see the machine start like normal if you need more help on this please contact me at andersonfarm1@gmail.com this worked for me
The power supply located in the back is failing, and causes the green light to flash, and the fan appears to move slightly. The only solution is to replace the power supply, or repair the failed part on it. Good luck finding information from Koolatron. The power supply is hardwired with solder connections. It appears to be a switcher power supply
Posted on May 07, 2008
    Problem Solver:
  • 12 Answers
Compressor is not starting . you might try a 3 in 1 booster pack.
Posted on Feb 27, 2008
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Driving down road and car just dies and wont start will turn over but wont start
run the fault codes
check that the cam shaft is turning ( broken timing belt/chain)
if it is a gm product check for an ignition switch fault and recall
Apr 24, 2015 | Cars & Trucks
My 1996 Chevy Lumina gets hot, then wont start. Is
there is a sensor that tells the ECM to turn on the fan/s however the most common problem is the cooling fan motors go bad and need replacing. If you disconnect the electrical plug at the fan motor and run jumper wires to it from the battery the fans should run if not then the motor needs replacing.
Oct 04, 2014 | Cars & Trucks
94 thunderbird heat or cold air doesnt blow
if you saying the fan wont blow it may need a fan motor not uncommon it might be a speed switch if it has one some time you can hook a wire on the back of the speed switch plug in to get it on high use a 14 gauge wire or bigger a small jumper bent in a loop with the rubber peeled off the ends and shove them in the switch plug find the 12 volt ht wire on the plug with light or vom then try the other wires one at a time til fan runs with ignition switch on
Dec 24, 2017 | 1994 Ford Thunderbird
My cub cadet wont restart after it gets hot
what engine do you have and how long has it been doing it for, try a new plug at first.
Jan 10, 2013 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
2000 buick century heater wont work
make sure that everything is plug in that runs the fan under the hood and shake the plugs to see if there a bad plug if not then it your fan then
Feb 20, 2009 | 1998 Buick Century
County road numbers
If it's a county road instead of searching a specific city do Search All instead and then type out County Road ####
Jan 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Koolatron (785169015699) Logo
568 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
