Question about Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Ice Machine Model KM-500MAF
Won't make ice,comp wont run,not running,pressure is at 73lbs. also beeps 3 times
  • 2 more comments
  • Anonymous Apr 01, 2008
    machine beep 3 time every 3 second
  • Anonymous May 31, 2008
    Cannot locate the reset button...I'm looking for the white reset but have had no luck. I am getting the 3 beeps. Is there a schematic of where the reset button is.
  • amimichele Oct 22, 2008
    Can't find the reset button, either. Moved the unit and let it settle. ???
  • Caleb Brunson
    Caleb Brunson Oct 25, 2016
    White button on board to reset alarm?? Got to take covers off find board and you cant miss it. Also for what it's worth an extended freeze can be caused by dirty condenser, dirty water distribution tubes, float switch adjusted out of whack, if outside def check condenser, condenser fan capacitor to make sure fan isn't over heating, fan cycle switch adjusted properly....
    Scholar:
  • 149 Answers
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Posted on Apr 26, 2008
    New Friend:
  • 54 Answers
Sorry condenser, float out of whack, cond fan capacitor(fan may over heat n shut off) fan cycle switch, dirty distribution tubes, stuck float, stuck inlet water valve
Posted on Oct 25, 2016
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 488 Answers
3 beeps hoshizaki ice machine. long freeze cycle. txv got shut. replacing txv
Posted on Oct 24, 2015
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
3 Beep Warning
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Nov 08, 2013 | Hoshizaki KM-61BAH 49 Pound Self-Contained...
3 beep code on hoshizaki km630mae
Freeze cycle too long. Usually about an hour. Many things can cause this. Look for water running even when machine is off. Stuck float switch causes this. may need a tech to check things out.
Feb 24, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have a Hoshizaki model Km-250baf it beeps three times.
3 beeps means it has been in the freeze cycle too long. A stuck float switch can cause this as well as a leaking water valve. Look for that first. Let me know if you need more info.
Feb 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
when the machine first starts, it begins it's cycle in the harvest mode. If the float switch is stuck, it stays in the fill/ harvest mode. Compressor runs and water circulates but no ice is being made. I'd start looking there. Turn the machine on, let it run for about 3 minutes, they very lightly tap the float switch. If it starts making ice, bingo, theres your problem. Let me know if I can be of any more help.
May 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Commercial Freezer KM-500MAH Logo
4,055 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
