Question about AOC 7 ELr 17 in.CRT Conventional Monitor
Monitor problem power is on but no display on screen ...
  • headsup Mar 05, 2008
    The power light comes on but there is no display. The monitor was plugged into a computer that works but still no display. The ram reset recommended does not seem to be the solution.
    Thank you for your help
  • 813 Answers
Open your pc remove the ram & clen the ram put it back then after tun it on
i hope your problm is sloved
Posted on Feb 27, 2008
When I turn my PC on you can hear it come on but the screen is black.
It sounds like you might have a problem with your video card. If you turn it on and see nothing, not even the gateway logo, than you either have a video card issue or a monitor issue. Hook up the mahine to another monitor to test.
Jan 04, 2011 | Gateway Computers & Internet
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
Display is fuzzy
Go into monitor controls on monitor and adjust as they come up. Unhook monitor, power up computer, cut off, plug in monitor power up computer, right click on screen, settings, adjust for screen size and additional monitor by clicking 2 and saying yes in box. Hope this helps.
Jul 05, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Monitor screen goes out (black) 2 seconds after turning on
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Thank's for nothing
Jan 16, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor
1.Check signal cable from VGA 9 pin socket
2.Check whether the monitor gets the power
3.. set default monitor settings in the monitor menu
4. Check for proper display timing in monitor screen menu
monitor display timing 48.3KHZ, 60 HZ
Dec 20, 2007 | Computers & Internet
AOC 7 ELr 17 in.CRT Conventional Monitor Logo
61 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
