Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
Won't turn on
I was playing video games and my tv just shut off and now it won't turn back on. i made sure it wasn't the outlet because everything else i plug in works, but the tv doesn't do anything any help?
email me matthew.myrfield@und.nodak.edu
or post on here but i would prefer an email.
thanks
  • RonWin Feb 29, 2008
    Same problem tv will not Power on. Any soloution and if it was fixed how much did it run and what did they do?
  • stevenbowen Dec 28, 2008
    My philips won't power up
    Problem Solver:
  • 5 Answers
Replace power supply. Part number LJ44-00118A . Available on e-bay.
Posted on Jun 26, 2009
    Genius:
  • 1,694 Answers
Always check power supply components first........T.
Posted on Mar 23, 2008
  • 92 Answers
I have replaced many SSB's on this model but obviously cant be sure
expect to pay 400-500 part and labor
Posted on Mar 12, 2008
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
Whenever I try to play my Super Smash Bros. Melee game with 2 players (me and my dad),It always automatic turn off. I tried every combination of black and white controller,but no working. WHY IS THIS...
Power Light Shuts Off
If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Feb 27, 2011 | Nintendo GameCube Console
My xbox 360 turns off whenever i play a game. We have two xbox's and one turns off very quickly when playing games, and the other turns off after about 10minutes of game play. This happens with all...
There could be several causes. If you’ve managed to run other appliances with the same voltage through these power outlets without them turning off then it won’t be the outlets themselves.
It could be the power cable; try swapping them to see if this affects the frequency (10 mins vs ‘very quickly’). If this makes no difference then it won’t be them that’s at fault.
The most likely cause (unless both are simply faulty) is overheating. The Xbox 360 produces a lot of heat and there’s a failsafe built in to turn it off immediately if either the fan is malfunctioning or it’s too clogged with dust to ventilate properly.
Make sure nothing is sitting on top of them and that all ventilation areas are clear. If you think there’s a chance they might have become dusty, get a can of compressed air to dislodge any built up dust in the vents & a vacuum cleaner to remove it.
Oct 09, 2017 | Microsoft Xbox 360 Console
Turns off automaticly
  • Power Light Shuts Off
  • Sep 27, 2010 | Nintendo GameCube Console
    No power The light does not come on. The game does not turn. The fan does not blow.
    • No Power
      1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
      2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
      3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
      4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
      5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
      6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
      7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
        If this fails, try resetting the AC adapter.
        1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
        2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
        3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
          • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
          • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
      8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
    • Power Light Flashes
      If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
    Dec 21, 2009 | Nintendo GameCube Console
    Surge protector shuts off while playing PS3
    swap to another surge protector. if it still does it, it is a power surge at the outlet, if it does not, the Surge Proctector has worn out. have someone with the appropriate knowlege have a look at the outlet as well. older outlets especially tend to wear to the point where the plug literally falls out of the wall.
    Jun 11, 2009 | Sony Playstation 3 (PS3) Console
    Power button failure
  • Sep 11, 2008 | Nintendo GameCube Console
    My wii will not power on
    Unplug the Wii from EVERYTHING....TV, the outlets...let sit for a while and plug everything back in. Worked for me
    Aug 01, 2008 | Nintendo Wii Console
    Tv shuts down
    something isnt properly grounded, I would suggest trying it on another tv and see if the same thing happens there.
    Nov 06, 2007 | Microsoft Xbox 360 Console
    Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
    207 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
