Question about GPS
Power on/off button not working on a garmin streetpilot III
The power on/off button is intermittant. If I continue to randomly push it sometimes turns on and then randomly turns off...should I crack it open and look for a problem with the touch pad connector?
    Problem Solver:
  • 5 Answers
At the top of the GPS thers a power button
take an eye glass flat head screw driver and pop the power button out there should be a rubber button the is pushed in and not touching the buttonpop out the rubber button and put the cap button back and it should turn on and off without a problem
Posted on Aug 26, 2009
Streetpilot III won't power on
The first solution is, of course, to try recharging your Streetpilot III by plugging it in to either your accessory outlet (cigarette lighter) in your car.......or a USB port on your PC. (preferably a USB2 outlet that has a higher power output).
Try charging for at least an hour with the 'other' cord, if the unit won't power up after using the 'first' one.
If the unit STILL won't power up after charging with BOTH cords (for an hour each), then either open the unit and replace the battery, or, sorry....if you're mechanically/electrically challenged......you're best to send your unit in to Garmin for repair, because it could be any number of different problems.
Michael
Feb 01, 2011 | Garmin Streetpilot III GPS Receiver
How to reset Garmin StreetPilot 7200 GPS Receiver
To RESET it turn the unit off, then hold down the menu and map buttons, simultaneously, then turn the unit back on and continue to hold down the buttons down for at least five more seconds, then the unit will power up.
Jun 16, 2010 | Garmin StreetPilot 7200 GPS Receiver
Can't aquire satellites
If it is a streetpilot 2720 also may work on other models...
Turn unit off hold down menu button while turning unit on and, hold button down till a white page comes up that says general.
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work it did for me.
May 28, 2010 | Garmin StreetPilot 2720 GPS Receiver
How to reset the Garmin streetpilot III deluxe
DO NOT DO THE FOLLOWING unless you know why you are doing it. If you press and hold ROUTE when the unit is powered up, you do a master reset. This will clear all data and user variables. Unlike previous Garmin GPS receivers, this will NOT clear the temp compensation curves and non user data.
If the MENU key is pressed and held when the unit is turned ON, an undocumented test screen is activated which incidentally measures battery voltage, temperature and a few other things. Pressing QUIT (several times) from the test screen gives you a set of display test screens.
Mar 27, 2009 | Garmin Streetpilot III Deluxe GPS Receiver
Gps not turning on
Have you tried charging it using the computer? This sometimes helps.
Feb 05, 2008 | Garmin StreetPilot c340 GPS Receiver
Bought StreetPilot III used, can't locate satellites
Are you using it outside or in your car? Mine will not pick up sats fron inside my house.
Yooper-Al
Jan 30, 2008 | Garmin StreetPilot i3 GPS Receiver
Garmin i5
Resetting Your StreetPilot
If your StreetPilot freezes (stops responding to button presses), try turning it off and then on again. If this does not help, remove the batteries and then reinsert them. Disconnect from external power, if necessary.
Clearing all User Data
If resetting does not fix your problem, you may need to clear all user data from your StreetPilot.
• IMPORTANT: zf you clear all user data, you will delete all saved locations from My Favorites I and all settings in your StreetPilot. Be sure you want to clear all user data before proceeding.
To clear all user data, press and hold down all buttons in the following order: ciJ, Wheel, Power.
Continue holding down all buttons until you see a prompt, “Do you really want to erase all user data?”
Select
Yes.
Jan 07, 2008 | Garmin StreetPilot i5 GPS Receiver
Garmin c340
Will the device turn on without the cord (on battery power)? If not then the cord is not the issue most likely. To make sure, you can use the USB cable and try charging via that hooked up to your computer (make sure computer is on). Give it sometime to charge (30mins) and see if you can get it to turn on. If this doesn't work, I think the next best thing is to contact Garmin support.
Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot III
Push the power button to turn it on then count to 5 then hit enter. Then count to 5 again then hit enter. Once there hit the power button with a real quick press. The power button is also the screen brightness button. Someone may have turned it all the way down. OR the back light could have gone out.
Aug 16, 2007 | Garmin StreetPilot 2610 GPS Receiver
GPS Logo
137 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
