Question about Fisher and Paykel Fisher & Paykel Washer
Washing machine problem
My washing machine takes longer time to start a programme after it takes the water in . Then after the rinse programme it has to go to spin but it again goes back to washing programme.
No it is old machine doesnt have any screen or like that to show the error
Posted on Feb 29, 2008
If I remember right the washer has err codes on it. Does it bring up anything?
Posted on Feb 28, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Machine only one direct rotation (Clockwise) even stop and can't be continue to working at all washing programme
it could be that the water sensor is not Working properly telling the programmer that there's water in or out of the machine unplug the machine take the back off and locate a small 5mm pipe leading upwards take it off and blow gently into it you should hear a click and one when you let the air out if so the place you took the pipe from is blocked not allowing the sensor to work correctly use a pipe(smokers) cleaner or metal rod to clear refit the pipe and rear panel run machine eric
Jan 18, 2018 | Samsung WF306BHW High Efficiency Front...
Wash programmes not changing
Unless meets water from tank necessary to check the pumps a discharge and clean him from rubbish.
Nov 12, 2013 | Hotpoint WMA46 Front Load Washer
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
Nov 26, 2011 | Bosch Washing Machines
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Dec 31, 2017 | Washing Machines
Whirlpool lsr 8233eqo runs over every time any help out there
The main things that will affect time on any programme are the flow rate of water coming in, flow rate of water being pumped out and the temperature of the water coming in and the amount of heating required to be able to run the chosen programme. If the water is colder coming in then it takes longer to heat up and hence the programme takes longer than expected. If there is any blockage in the outlet pipe or blockage in the filter or pump it takes longer to pump out the water at each cycle and therefore the programme takes longer.
Nov 17, 2009 | Whirlpool Washing Machines
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Feb 10, 2008 | Neff W5340X0 Washer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
