1995 Cadillac Seville Logo
Posted on Feb 17, 2010
My 1995 seville battery wont hold a charge.on the
My 1995 seville battery wont hold a charge.on the information display it says battery no charge.what is wrong?
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Feb 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
Helped
3548
Points
15
You may have a bad alternator... you can have it checked at any auto store for free... Also check your positive/negative wired connections...your connection to your positive cable that goes to your starter may need to be replaced, or your negative cable could be bad also.
tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
New battery and altenater still has battery draw,now wont start
i would have the charging system checked, it could be a faulty new alternator.
Ac wont hold charge compressor shuts off on my 96 cadillac sls
the most likey cause for the leak is a leaking a/c compressor or a leaking evap core located inside the dash board on the passenger side..... the compressor will automatically shut off when the a/c system charge becomes to low since low pressure can damage the system if it is on with a low charge
3helpful
When I start my 1995 sls the "Battery No Charge" warning comes on the dash. After driving for while the light will go out and the display will say Battery charging. But the display also says...
You need 13.8 to 14.5 volts for proper charge. I suggest that you pull the alternator and get it bench tested. There is a diode trio that controls the regulator, and when a diode fails, issues like what you describe, happen.
1helpful
My 1995 cadillac seville sts wont shift out of 3rd gear. when i get to about 60-65mph my rpm are at 3-4 thousand.
could be shift solenoids . on ebay for $50. are located in the bottom of transmission. remove pan and u should see the valve body it has about 20 screwes in it unbolt it it is a 10mm socket u will need. take it out and unbolt the back side of throttle body be carfull to remember where the little berings . now use a screw driver to pull the clipps holding the shift solinoids in place and reinstall
The car won't start and the power is very low.
check battery cables for tightness and free from corrossion.if all is good .charge battery.it should be 12.5 volts.if wont hold charge replace it.also check alternator make sure its charging.crank car while idling.it should be 13.5 volts to 14.5 volts.
2answers
High idle on 95 cadillac seville 32v Northstar 103,000 mi
trottle position sensor out of range. hold down warrmer and off button on the cluster it should display codes . write them down and post them on fixya.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
