Question about ASUS Striker Extreme Motherboard
ASUS STRIKER FORMULA
My mother board is powered up, all fans working lights( cpu tested and woking, graphics cards tested and woking On another system) but the M/B won't intiate the cpu (q6600) and the LED dispay it read CPU INT. If there was a fault the display would give me a fault code or something wouldn't it? Is there something I haven't done or should do to get it going?
  • Anonymous Jun 12, 2008
    my system will not reboot
Cheddar
Posted on Mar 10, 2008
    Genius:
  • 1,019 Answers
This Is A Processor error Message, CPU ( Central-Processing-Unit ) INT ( Intermittent Fault ) wrong Type Installed. ( Faulty Processor ) Disconnected Fan-Wire To Motherboard ?
Or if It,s INIT Then It Fails To Initialise The CPU.
Is The Board Auto-detect Settings ? Or Jumpered ?
Mike @ Compurepair.
** Please don,t Rate This Post until Your Problem/Issue Has Been Resolved**
Posted on Feb 27, 2008
Does asus p5n73 am mother board support asus ati radeon HD 6450 graphic card? my smps is 450 watt also let me know which graphic card support my mother board
your power supply is at the edge, so i'd suggest going for 650W power supply. your mainboard will support the graphics card but as i said - you need better PSU
Mar 13, 2012 | ASUS HD 6450 DDR3 PCIE Native HDMI SILENT...
What mother board should is best for use on this video editing,engineering,and games with better graphics and can also work for more than 18 hours?
The best computer mainboard, would be either an AMD AM3 mainboard made by ASUS. For example ASUS Crosshair IV Formula or ASUS M4A88TD-V EVO/USB3. Or an Intel computer mainboard. ASUS Socket 1156/1155/1366.
Your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket is not good for Games or video.
The best thing to do is to purchase a new computer system.
Use either AMD Phenom 2 or Intel I5 or I7.
Use a good mainboard as above.
Use a good Graphics card, Nvidia 400 series.
Keep all the components running cool with a case that you like and has place for lots of 120mm or 140mm fans.
Use DDR3 RAM 1333MHz or higher.
Use Cooler Master or Corsair Power Supply.
If however you are wanting a good mainboard to be used with your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket then click here.
ASUS is very good, all these mainboard on the LGA775 socket are good, choose one that looks good to you and one that you can afford.
Thanking you kindly
damnor01
Feb 02, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
I have a asus striker extreme motherboard, quad core Q6600 processor, 8800 gtx graphics card, my pc was running fine suddenly it just hanged ,this has happened a few time before but after a while it starts...
Sounds like you need to go into the Bios if you know how and adjust the thermal values in there. I suggest checking heatsink on cpu is seated correctly and add a fan to increase airflow in side the case. Seems like a heat problem from what you describe.
Dec 14, 2009 | ASUS Striker Extreme Motherboard
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
Asus Striker II Formula
try to boot up with minimum configuration ie: graphic card , and memory, check BIOS configuration
Sep 25, 2008 | ASUS Motherboard Striker II Formula
Asus Striker II Formula CPU INIT
u motherboard stop of working is fault get another one from a it very professional
Sep 01, 2008 | ASUS Striker Extreme Motherboard
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
K8NGM2 Mother Wont Power Up
I've seen situations similar to yours several times and they've always been a bad CPU.  Since you tried a new video card it's not that, I would suggest a new CPU.  Check on ebay, you can usually find used one's on there.
Oct 10, 2007 | ASUS A8N-SLI Motherboard
ASUS Striker Extreme Motherboard Logo
316 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
