Question about SanDisk Sansa e250 MP3 Player
Cannot move beyond plugging into USB .What next? help
After I plug in the MP3 player and I see the zzz that suggest that it can be connected.There is no other action neither sound or movement.
What can I do?
  • Seeleaux Feb 29, 2008
    I have the same problem. Plug in --device says refresh data base, connects to Rhapsody, and as soon as it searches the device, Rhapsody shuts down. Device is locked saying connected, until it shuts down or I hold the menu button down for 20 - 30 seconds.
  • 34 Answers
Try to connect it without rhapsody open while you plug it in.
Also try to transfer music via explorer
Posted on Feb 29, 2008
Speedo MP3 pink 1 gig. When I plug into my Mac (yes, Mac hooked to power source; yes, plugged directly into the Mac's USB) I continually get a message saying I've ejected incorrectly. Then shortly...
It probably means your usb connection is loose. You can try another usb port on your mac, if that is better then the usb port you usually use is bent or has a loose connection, if not the problem is likely the MP3 player's usb.
You could try putting a small amount of weight on the MP3 Player while its plugged in to improve connection. While it is plugged in, use your finger to lightly move the device up or down and hold gently. If the connection improves, use a small weight to hold device in that spot. If you are pushing down put a small box on top of the device, if you are pushing up, gently wedge something underneath drive.
Hope this helps.
Sep 20, 2017 | Speedo Aquabeat (2 GB) MP3 Player
Sony walkman NWZ-S615F won't connect to computer
well, i searched up many solutions, but i ended up making my own.
step1 : connect your mp4 to the computer using the usb cable that was provided.
step2 : when the install wizard pops up, click the one with advanced.
step 3: click the one that says you will choose where to install it from
step4: check USB mass storage device.
i hope this helps many people, since i searched everywhere for a solution
Sep 07, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
Computer doesn't recognize usb connection
follow this process
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
same process with anotherone then restart your computer and enjoy you ipod
and don't forget to give rating
Jun 16, 2008 | Coby MP-C7085 MP3 Player
Will not connect with the computer
follow this process
1. click properties
2.hardware
3.device manager
6 go to driver
Delstar DS 31024 will not connect
if the mp3 shows zzz's it is waiting on you to copy something into it. :-)
Jan 03, 2008 | Delstar DS 31024 MP3 Player
Not connected ?
lolz same bloody problem with both mine n mah sis's...
they should fix this **** fast...
or put a patch out or sumthing...
i installed
plugged it in n got jack for response
i reinstalled (many many times)
updated comp...
tried other devices (which worked excellently)
nuthin wrkz
have all teh requirementz 2
meh **** happens right?
we want a patch!!!!
Dec 30, 2007 | Creative Labs ZEN V Plus MP3 Player
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Samsung YP5 Mp3 Player - When i first bought from my friend the player.. i cannot charge it.
If i start my MP3 samsung yp-K5 i wont start any more and when i plug in with the usb he need software to read my Mp3?
Can You help me please
Sep 06, 2007 | Audio Players & Recorders
E200r - Can't see new music.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
