Question about Philips 20PT6441 20" TV
Fix the color on my tv
My tv is red, how could i get the right color on my tv. is 42 inches phillips tv
How could i get right colors is 47 inch philips tv
Posted on Feb 04, 2011
  • 54 Answers
Sir/maam kindly adjust its screen focus of your tv,,,,thankss and hopetohelp you,,,gud luck!!
Posted on Feb 27, 2008
Hello my Phillips 42" model
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
My sony TV trinitron wega 42 inch picture is red. Is there any solution to remove the problem?
The problem with your TV trinitron wega is at the color adjustment section. It is located at the color board mounted at the back of the picture tube. There are variable resistors that represents the color pattern in the picture tube. Adjust the red color to low level to lower the red color.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a Phillips 42 inch Plasma. I tried
One of two issues/problems:
1) Main Power supply problem
2) High Voltage Power supply problem.
A Good TV Service Shop that works on Philips would be the first place I'd call. It will be much cheaper to bring the TV into the shop instead of having a tech come out to your location.
Possibly a $200 to 300 dollar repair.
A/V Media Guy
Nov 23, 2009 | Televison & Video
My 42 inch lcd phillips tv turns on and of by its self and freeze
If it is still under warranty address this. The problem is the signal board. The one with rca jacks and RF connectors.
Aug 19, 2009 | Philips Televison & Video
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Have a 55 inch older tv color is starting to fade like a rainbow red and green can I get this fixed for a cheaper price of a new one
go toa tv repair shop and tell him to recharge the tube or tell him to change the   colour ic which will get better
May 19, 2009 | Philips TV Tuner Video Capture PCI Card -...
Our 52 inch Phillips Plasma tv is not working
open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Feb 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Red in left sie of screen show up sometimes on 42 samsung SP P4251
What component(s) are you connected to this TV?And what type of A/V cables are you using?
Does it only happen when you watch cable or directv or dishnetwork?
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Philips 20PT6441 20" TV Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
