Back to:
Tags:
Motherboards
Generic problem for all Motherboards
Mother board p4m80 biostar
posted by redchips57 on Feb 27, 2008
my motherboard is a p4m80 biostar
Comment by redchips57, posted on Feb 27, 2008
i don't know if there is a problem with my board.i just gave you the board number because i thought it might be helpful.my question was do you think maybe my power supply can't handle the 2 gigs of memory that i just installed.it's a 430 watt supply.or do you think that there could be another problem causing the double boot.thankyou
Comment by redchips57, posted on Mar 01, 2008
raj,with all the great help i got from several of you guys i was able to get my puter going .thanks again!!!!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
raj432006
Rank:Master Master
Rating: 83%, 8 votes
can u give me what is that problem with this board ?
Comment by raj432006, posted on Feb 27, 2008
that means your pc can't work so u have to check that your smps working or not if it is working then check the connector inside the cabinet. Then u have problem then tell me taht yr VGA out put ok or not.
or
remove 1 RAM then check. may be one of yr RAM slot is damage.
Rating Locked! (?) redchips57 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on mother board p4m80 biostar:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Asrock K8Upgrade-VM800 Motherboard
i have a problem with sound drivers in my laptop
hi , how i install sound driver on my loptop. plz give...
EPoX EP-8KMM3I Motherboard
I can't get any wifi card to switch on when installing it...
Asrock M266A Motherboard
i have no sound driver fo my pc so plz send me the sound...
MSI KM4M-L Motherboard
i can't find a manual for my specific km4m ver;1...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
