Question about Whirlpool GEW9250 Electric Dryer
Whirlpool electric dryer
Thermal fuse blew. Cleaned all exhaust ducts and replaced fuse with new. 1 week later same thermal fuse blew, why?
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like something getting to hot, perhaps clclyng thermo not regulating temp properly, although cleaned vent, when you pushed it back ito place did you crush or hkink line? peek over top and check
Posted on Feb 28, 2008
No power
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2011 | Whirlpool GEW9868K Electric Dryer
Steam will not shut off
Kevin
Dec 01, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
    the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
    Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
    Dryer wont get hot
    Did you replace the Thermal FUSE? Or, the Thermal CUT-OUT? If the thermal fuse blew, the dryer would not run at all. If the thermal cut-out blew the dryer would run, but would not heat. The following link explains how to troubleshoot a dryer no heat problem:
    http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
    Its great that you've cleaned all the duct work. That's usually the number one reason why dryer's fail. Poor ventilation causes the dryer to overheat to the point of failure. Now....before you go tearing the dryer apart again, did you verify the voltage at the wall receptacle? If you are missing a portion of the input voltage, the dryer will still run, but the heating circuits won't work. That's because the drive motor only requires 110-120VAC to run, while the heating circuits require 220-240VAC. If you have confirmed your input voltage is good all the way to the terminal block at the back of the dryer (read across the RED and BLACK leads), then the problem is your heating circuits. If the voltage is good at the receptacle, but bad at the terminal block, you have a bad power cord.
    As far as what you have attempted so far, I'm not trying to undermind your abilties, I just want to confirm we're talking about the same components. Many people confuse the Thermal Fuse and Thermal Cut-Out. Although they perform similar in function, they are located in different locations in the dryer electrical circuits. Please read through the info I provided and let me know if you have any questions. All the readings you should get are provided. I hope this helps you isolate your problem.
    May 04, 2009 | Whirlpool Dryers
    Thermal fuse blew again.
    One thing to check would be the blower. I'm not familiar with your model dryer, so I can't tell you how to get access to it. But if the blower is loose on its motor shaft, it won't move enough air and this can lead to tripping the high limit or thermal fuse failure. You may find a mounting clamp has come off, or the blower wheel may need to be replaced.
    Mar 31, 2009 | Crosley CDE6000 Electric Dryer
    either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
    Feb 27, 2008 | Dryers
    Hotpoint NVL333EY Electric dryer blows thermal fuse
    I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
    Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
    Blown thermal fuses
    I would think not. The MAIN cause of that fuse blowing is lint build up. Turn the dryer on and put your hand on the outside of the vent duct. Is the air blowing hard? If so, you will probaly be ok, if not maybe your blower wheel needs to be replaced...
    Dec 15, 2007 | Whirlpool LER5636P Electric Dryer
    Whirlpool GEW9250 Electric Dryer Logo
    116 people viewed this question
    Top Whirlpool Dryers Experts
    Sal De
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
