Question about Dishwashers
Where does the powder go?? Sound silly i knoe.
I have just purchased a HAIER by LEMAIR benchtop dishwasher off good ol EBAY. however no instructions or manuals came with the unit and seller will not return my emails since feedback left. Anyway, where in the world do i put the powder/tablet. On the inside of the door there is a little smooth cutout, but if i close the door anything i put in there will just fall to the bottom. A friend suggested it just goes in the bottom and when the machine fills up it will do its job?? However there is a little pocket at the back corner, a bit out of the way for powder, but maybe it is. Can anyone shed any light for me? Also.....there is a drainage grill in the bottom with what looks like a heating element under it, the grill though only just sits in place, it seems that when the machine will fill this grill will just float out?? Im guessing its there to catch food. but wont do any good if it floats off every wash. Is this how its suppose to be?? will it float off??
Cheers
Your friend is right, I usually just use a tablet and put it in the dishwasher and close the door. No the grill will not float out, it is to catch the food, for easy removal when dishwasher has finished its cycle.
Posted on Mar 04, 2008
Upgrade kit pdf file
Heard lots of problem with similar case for this tv,you need to buy upgrade kit from the haier itself, there also available at Sears you will get instruction sheet will contain all information all you need is screw driver to replace the parts Control Board TV-5210-39, Y-SUS TV-5210-35, Z-SUSj TV-5210-37, New EPROM Chip 2006 version TV-2455-03, Upgrade Label TV-4050-08 and Haier Service Bulletin SB-TV-0003 containing the instructions to replace the boards yourself.
Good luck..
Sep 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
My mugs and dishes are not coming out that clean and the inside of the dishwasher looks dirty after the clean cycle has run
Try this first..
Go to your local Walmart and purchase a bottle of dishwasher magic.Follw the instructions on the bottle to clean the machine. in some cases this may take several attempts to clean out all of the hard water deposits...
Then use a product called Lemishine (about 1/2 full in the main wash receptacle and other half detergent) with a good powdered detergent this solves this problem 90% of the time.
If this does not help then further investigation would be required. Look for broken or damaged spray arms or anything the may be causing improper water flow.
Jun 07, 2011 | Amana 24 in. ADB1200AW Built-In Dishwasher
I have just purchased 2nd hand a Haier by Lamair benchtop dishwasher, It trips the power. Is this fixable or a known problem?
dishwashers can flick the trip....
try running d/w without anything else running.... ie washing machine etc....
see if it works ok....
cheers
Jun 02, 2011 | Dishwashers
Hi, My Bosh lifetstyle dishwasher purchasedin Dec. 2010 is just about 10mm to high to insert under kitchen benchtop. Is there a way to remove the top of the dishwasher because then it would...
If it is a brand new dishwasher you should not be making any alterations to it otherwise it can affect the warranty.
Best to call the company representative and ask.
Dec 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Can I get a Goldstar Benchtop dishwasher manual for model: GDW 051T ?
CONTACT THE MFG CO. OR DEALER WHERE YOU PURCHASED. THEY WORK LIKE OTHER DISHWASHERS OTHER THAN THE WAY YOU CONNECT THE WATER HOOKUP AND DRAIN.
Feb 26, 2010 | Dishwashers
I have just purchased a second-hand Sercon Quickwash benchtop dishwasher. Is it possible to get operating instructions for this? The type No. is CB 2405050-6 and serial No. is 8350144.
Congratulations, you've just purchased one of the most indestructible dishwashers ever made. I ought to know, as mine is 35 years old, used at least twice daily and still going strong after only the addition of a door switch pushrod seal, a heater element and a water level switch in that time, although now on its third plastic door. They were often used commercially in labs for cleaning test tubes, etc. as the components were able to take the chemicals and punishment. Alas the plastic doors eventually crack around the hinges and need replacing but are no longer available so treat yours tenderly because if it cracks and can't hold water your dishwasher will be a boat anchor. You don't need an instruction manual, although I have one. Just use Finish dishwashing powder(no I don't own shares) and no rinse aid (the rinse aid dispenser is at the back and a pain to fill anyway and not necessary because you're using Finish remember?). Click on the water/waste pipe connector to the sink tap fitting, turn on the cold water, fill with dishes, sprinkle a capful of Finish powder over them, close the door and turn the timer clockwise ONLY to the Start position (about 1 o'clock) and wait about 20 mins til its finished (timer at about 11 o'clock) Then open the door to let out steam and aid final drying. All this with the toggle switch on 'normal' (and power plugged in and on of course dummy), although you can use 'economy' position for a few dishes or drink glasses, remembering that dishwashers will eventually turn glassware milky with that blasting action (ie not mum's best crystal) The Sercon Quickwash is a mighty mouse but noisy as it's not insulated around the single skin stainless steel cabinet and if the usual suspects aren't careful with bones, pips, stones, etc the waste pipe can become blocked, usually at the fitting near the tap and the cycle may stop with water still in the dishwasher. If it does, undo the hose and check for any obstructions, clear and restart. Farewell dishmop until the fateful day that plastic door cracks.
Feb 19, 2010 | Dishwashers
Cabrio toploader keeps displaying oL error code even if only a few items.. Been in storage for a few months..
I've been through the F1 and the OL issues. Regarding the F1 error, I had to have a new controller installed after I talked Whirlpool into providing it. Regarding the OL issue, I just purchased a new suspension set (long rods w/ springs suspending the tub from the frame) through Ebay that fixed this problem. The problem is with the suspension springs which weaken over time. The rods and springs are easy to replace once you hinge the machines top up and back. You won't believe the "springy" difference, or lack thereof, between the old "sprung" springs and the new ones. Additionally, the new set includes plastic cups, in lieu of grease, which go on top of the frame to cradle the new rod caps. The suspension spring set I bought off Ebay for my WTW6600S was part number W10189077 for approx $31 w/ shipping. Thank goodness the constant banging and OL error is GONE!
Jul 06, 2009 | Whirlpool Washing Machines
Upgrade instructions on the way to your email address. Hope it helps!
May 27, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Dishwashers Logo
511 people viewed this question
Top Dishwashers Experts
