Question about Maytag MER6875A Electric Kitchen Range
Ovens not working
We have a MER6875ACW both ovens have quit working and the display panel is not responding, have a diagonistic code off of it 1c2c, what can we try
I replaced the control board and display, but it appears the touch pad is the problem. Can I buy it separately?
Hello. The part number you need for the control panel/switch assembly is 74011491. The actual oven control unit is 74011494. The following list shows some(but not all) of the error codes you might encounter. I hope this helps you!
1c1c shorted key
1c2c membrane keyboard disconnected
1c4c board to board communication failure...." "
1c6c EEprom hardware fault..........................." "
1c7c control not calibrated............................... replace main board
1c8c eeprom crc error--user options..............." "
1c81 eeprom crc error--cook profile................." "
4d21 no cooling fan rotation
4d31 cooling fan on when de-energized
4d41 cooling fan overspeed
4d51 door switch circuit fault
In the service manual, there was no "warming drawer" error code listed in the code chart.
Aug 29, 2015 | Jenn-Air JES9750BAS Stainless Steel...
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Double oven control panel just quit after power surge.
This is unfortunate.
The display is a computer you need to do most of the work.
Go Onlne to www.partselect.com and order that display. You will need a friend or a service guy to open and install you new display
Jul 26, 2010 | GE Profile JTP18 Electric Single Oven
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
After a power blackout in our neighborhood the oven display showed a blinking clock time-still keeps time- which could not be reset. The soft panel does not respond to any setting to turn on the oven in...
Try turning the breaker to that unit off and keep it off for 20 minutes or overnight, if possible, then flip the breaker back on. If it still shows the PF code, call us and we can get the correct part to you. Hope this helps.
Aug 28, 2009 | GE JTP20 Electric Single Oven
Whirlpool GH6177XPS3 Touch Error display
I've got the same problem and error code. Did you ever find the fix?
Jul 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Maytag MER6875A Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
