Question about Panasonic KX-T7730 Corded Phone
Coding Dear Sir, I am using the phone set PANASONIC KX-T7730 in my office. We have around 12 extensions with 4 Connection. I want to stop all the general mobile call from all set along with the master set. Only one extension will be open for all call. As well as some particular mobile number I want to access from all extension. I think here is some programming code with which I can activate this system. I will be grateful to you if you let me know regarding this. For your kind information Our PABX system is PANASONIC ? ADVANCED HYBRID SYSTEM ? KX-TA616 Thanks & Regards Sajid Hossain General Manager New Horizons CLC 110 CDA Avenue, Nasirabad, Chittagong, Bangladesh Email: sajid.hossain@newhorizons.com or saj_nh@yahoo.com
  • poging
    poging May 11, 2010
    Please give exact local number of the extension you wanted that have access/open for call.what do you mean on the particular mobile number?
2 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: Our office pabx is a
Look carefully at the part number on the phone and where you posted. A Panasonic 7730 set has 24 buttons, 12 left side C.O. buttons and 12 right side PF buttons. A TA30830 (new style) has 12 buttons with LED's. In our country, the TA30830 needed 824 version 2 or greater software to work.
In your country the other mate to that is the KXT-7667.
If your phone is one of those and actually works, as in any Panasonic set, the LED buttoon requires a "2" in front of the digit sequence to tell the system it's a PF button.. So, PROG button 2+access code+number STORE saves a speed dial. The access code is what you dial to get an outside line.
Carl
Posted on Jul 06, 2011
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I have a panasonic kx-t7730 phone. A techie set up call forwarding from the phone to another extension, and now I can't remove it. Can you help?
    From the intercom, dial 7100 or 710#. Call forward codes are set via 71x and the extension plus #.
    This is the TA series code set. The bigger systems have 710x codes.
    Carl
    Mar 29, 2011 | Panasonic KX-T7730 Corded Phone
    How can i use the buttons of panasonic kx-t7730 corded phone ?
    The 12 buttons on the right can be used for personal speed dial numbers and features like paging. They are programmed by pressing PROGRAM dialing codes and STORE. An outside call would use an "access code" usually "9" plus the number. Paging is 330.
    The 12 left side buttons are very valuable as they have lights. You can store lines, extensions, and features that require lighted buttons, such as CID Indication or VM functions. They are programmed by PROGRAM the button a code the feature and STORE. For example, lines are programmed with 0 + line Extensions with 1 + ext and CID Indication System with 96 or the 9x voice mail commands.
    Your OM or User's manual has a section on flexible button assignment with the codes and buttons required to do the programming. In my TA-824 200-OM it's in section 3.1.3.
    Carl
    Feb 19, 2011 | Panasonic KX-T7730 Corded Phone
    Hi we have 4 Panasonic KX-T7730 phones in our office and 2 of them have stop ringing they are still receiving call but there is no tone to make you aware that its ringing!!
    When customers ask this question, it's usually because someone has turned off the ringer on the phone. A 77xx phone has a 3-position ringer switch on the left side of the phone. It's pretty easy to turn it to OFF.
    If you have somehow asked the question and the phone really doesn't ring, try swapping it with a working phone. If it still doen't ring, then it may be that the extension is not programmed to ring, but you didin't ask that question.
    Carl
    Jan 11, 2011 | Panasonic KX-T7730 Corded Phone
    Lock extension with my Panasonic KX T7730
    Do you need the default lock code because you already did this, or is it locked and you can't unlock it?
    This is probably close, but in the American version it's 77 lock lock # to set and 77 lock # to release, where lock is a 4 digit number.
    The System manager can release all locks from their phone. You'll have to make arrangements with an "engineer" to get those codes.
    Carl (working on Br terms)
    Jul 15, 2009 | Panasonic KX-T7730 Corded Phone
    The incorrect name being displayed when you use a preset number
    The side buttons is programmed as extensions
    To change the extension names follow these steps :
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
    3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
    4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
    5. Press PROGRAM to exit program mode and you are done.
    Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
    For assigning a person name to the extention
    Jun 18, 2008 | Panasonic KX-T7730 Corded Phone
    KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
    please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
    Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    73 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
