Question about Cameras
My first roll of film came back all blank. Not even one negative was underexposed. I have just bought a Nikon F6 film camara.
    Problem Solver:
  • 11 Answers
Just to make sure, if you do see the picture on your negatives, then the problem most likely lies within the developer. Try somewhere else and see if that works for you. If not, then you can use another type of film. The film could have been mishandled when manufacturered. These cameras don't usually have problems so that would be the last thing I would look at.
Posted on Feb 27, 2008
What type of film does a n60 slr camera use
The N60 uses standard 35mm film (also known as 135). 35mm film usually comes in 12, 24, or 36 exposure rolls, any of which will work. 35mm film is available in black-and-white, color transparency (color slides), and color negative (color prints). It's also available in infrared, both color and black-and-white, but the N60 will not work with infrared film.
35mm film is available online and at any camera shop. Many department stores, drugstores, and even supermarkets also carry film, though not as wide a selection as a decent camera shop.
Oct 11, 2014 | Nikon N60 35mm SLR Camera
I recently shot three rolls of color film with my ZX-7 in auto pict mode and all the negatives turned out blank (underexposed). What happened?
The shutter assembly has failed, a common fault with all older autofocus SLR's. it's nothing to do with the autofocus itself, just that AF SLR's usually tend to have fully electronically operated shutters which cannot be serviced and repaired like older models.
The only fix is to replace it, but it's no longer available and even if you do find one the repair is not economically worthwhile.
If you're not too choosy as to the brand, then free similar SLR models complete with lenses are regularly available on FreeCycle and Freegle. It's where I got all of mine.
May 13, 2010 | Pentax ZX-7 35mm SLR Camera
lens cap ? ;-]
Did you have the asa film speed set correctly? Thats usually the cause unless your battery isn;t quite right.
Mar 23, 2010 | Pentax ZX-7 35mm SLR Camera
I dropped off several rolls of film to be developed from my nikon 35mm slr. the photos came back with an odd almost tan tint and the colors were dull and wrong. could this be a problem with the camera or...
Slide or negative film? Is the coloring wrong just on the prints? If so, it could be that they just screwed up printing. I'd take the prints back and demand a new set--or my money back.
Dec 21, 2009 | Nikon Photography
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
How do i change ISO/ASA on the nikon N65?
The ISO is automatically set by the DX code on your film canister - if there is no code, the camera sets ISO 100. If you load canisters yourself with, say ISO 400 film, you can adjust the exposure using the exposure compensation button at the top right side of the LCD ( " +/- " ). Using ISO 400 film set the +/- to minus 2 ( -2 ) so that it will UNDEREXPOSE 2 stops since the film is 2 stops ( 4X ) more sensitive than ISO 100 film.
Nov 18, 2008 | Nikon Cameras
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Changing lens
Your Nikon is a SLR which stands for single lens reflex. The reflex part is the way the mirror that lets you look through the lens to frame the picture flips up to let the light go straight to the film. You can change the lens half way through the film roll because the mirror is down while you change the film and blocks light from getting to the film, just as it blocks the light until you push the shutter button. Have fun with your 'new' camera! I use an even older style Nikon FE2. I like my Nikon 55mm macro lens but your newer camera takes autofocus lenses so you'll need advice from someone else for that.
Oct 01, 2008 | Nikon F65 35mm SLR Camera
Film winder is loose and meter is not accurate.
It is absolutely OK, my dad too has one (not older than urs). make it tighter, but u need some screws drivers (specially for cameras). Open the camera and tighten the screw holding the winder arm. Try this only if u have experience otherwise u may end up with a scramble of camera. About the F-Stop, i have no idea why this is so... might be the technology is gone too advanced compared to the 1978.
Aug 14, 2008 | Nikon FE 35mm SLR Camera
Problem in camera or film roll??
Hey msenile,
It is possible that each frame would have image data imprinted without and image being exposed. This could be caused by the shutter not opening while the camera still exposing the film internally with the image data recorded. It is unlikely that this bad film since the emulsion covers the entire surface of the film and if it were bad the image data would not be recorded either. Another cause of this but very unlikely is every frame was somehow extremely underexposed. This could happen if the camera is set to manual and the light level is low and the shutter speed is set to a fast speed and the aperture is set to a very small aperture. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 18, 2008 | Nikon F80 35mm SLR Camera
Cameras Logo
61 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
