2004 Saturn ION Logo
Posted on Feb 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you reset the oil change required light on a 2004 Ion
Anonymous
Level 3:
President:
  • Master 1,608 Answers
  • Posted on Feb 17, 2010
Anonymous
Master
Level 3:
President:
Answers
1608
Questions
0
Helped
748741
Points
5514
Press and release the trip/reset button until the oil life message is displayed.Then press and hold the trip/reset button until and chime is herd 5 times and reset is displayed in the message center.When the system is reset the odometer will be displayed in the message center.Turn the key to the off position.When you turn the key on if the change oil message is still there it did not reset.Retry again.Hope this helps.Good luck.
ZJ Limited
Level 3:
  • Saturn Master 17,989 Answers
ZJ Limited
Saturn Master
Level 3:
Answers
17989
Questions
0
Helped
14456635
Points
60858
Work in 2002 All Models:
Turn ignition switch to on. Locate the fuse box under the hood on driver’s side. Remove cover and depress OIL-R button. Light should flash indicating reset. Instructions are located on fuse box cover.
Hope helped (rated this).
3 Related Answers
Anonymous
  • 3533 Answers
  • Posted on May 30, 2009
SOURCE: How to reset change oil light on 06 Saturn Ion
try this website to see if they have your car listed its www.edmunds.com for a online owner manual
Anonymous
  • 5 Answers
  • Posted on Nov 23, 2009
SOURCE: HOW DO YOU RESET THE CHANGE OIL DISPLAY ON A 2004
Press the trip reset button until OIL LIFE RESET is displayed then press and hold until it goes out.
Anonymous
  • 5081 Answers
  • Posted on Jul 18, 2010
SOURCE: 2004 Saturn Ion oil change
Oil drain plug is its on the back passenger side of the engine out of sight unless you under the car itself .
It's a cartridge filter that goes into a canister.You'll need a 32mm oil filter canister socket to remove the cover to access the filter. You can find it at PepBoys for less than $10 by the other oil change supplies.
2helpful
3answers
Honda Accord 2004 with 44,000 miles yellow light stating Maintenace required. Change oil recently.
you might have changed the oil but the car is telling you that it needs a service and when this is carried out a reset is required...
2helpful
Wat is the oil life reset buton do on a saturn ion 2004
after oil change this is pressed to reset the change oil indacator on the dash
2005 Saturn ION dashboard alert: picture of a car with a lock. also change oil light remains on constantly and it is not due for oil change nor does it need oil.
you can reset the oil light by turning the key to on, but not starting it, then push the gas to the floor twice, then again...it should say oil life reset
2helpful
2answers
HOW DO YOU RESET THE CHANGE OIL DISPLAY ON A 2004 SATURN ION CAR AFTER AN OIL CHANGE?
turn the igniton switch to ON, and depress the gas pedal 3 times. watch the light it should go out. sometimes you have to do it, more than once.
1helpful
1helpful
Oil change required light wont go off
It has to be reset each time you have your oil changed.
To reset it press the status control button on message center to access the system check function. Then press reset to reset oil % the press and hold reset control to set it to 100%
3helpful
Change oil light stays on even after oil change
if you look under the hood there is a black box it is the fuse box. pop cover off and you will see a little red button in there this is your oil reset. Turn key on engine off and hold button down for 15 seconds light should start flashing this will indicate it is reset.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
