Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Projection bulb, wd62525
Why is it that the thermal fuse of the projection bulb ballast is burn out?
    President:
  • 4,402 Answers
Huh?
Posted on Feb 27, 2008
SONY GRAND WEGA 42" replaced the bulb and now it takes a long time to come on
this problem could be a defective bulb or wrong type you put in, or a defective lamp ballast and/ or thermal fuse. if you are a technician you can change both, or refer to outside service for repair.
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
HOW TO REPLACE LAMP
Check on You Tube there is a video that will walk you through it. Be sure it is the lamp that is the problem before you spend your hard earned money.
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 21, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Tv has no picture or sound. replaced bulb no help greenlight blinks 79 times. red lights start blinking
Jan 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Trouble with tv coming on to long and new bulb didn't work
Is the lamp light blinking twice every 5 seconds or once every 5. Once every 5 sec. lamp failure,...twice every 5 sec.. ballast or thermal fuse. The ballast is discontinued and must be rebuilt or purchased used,.....try Ebay. NO TV REPAIR SHOP IS GOING TO HAVE THE BALLAST! They may be prudent enough to check into and find the rebuild kit for the ballast. FYI a rebuilt ballast costs around $175.00 ,....the rebuild kit costs anywhere from $12.00-$55.00
Jan 06, 2010 | Panasonic PT-50LC13 50" Rear Projection...
SONY KDF70XBR950 DLP TV 6 Blinks. Is it on the G1 Board? and does anyone know the fix? Thank You.
First double-check all your connections and wiring. Make sure there is nothing looose or broken. The capacitors also could be swoolen and burned out. You can test with capacitor tester. Thermal fuse or flyback is also possible and common causes. Lamp burn out? Do you have power to the bulb socket? Power to ballast that bulb attaches to? Last solution wold be to replace the board
Oct 27, 2009 | Sony Televison & Video
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Lamp will not light
At first i was thinking the ballast had gone bad but after reading a few other post i think it would be best to call pannasonic..
others forums read:
ballast had gone bad. Panasonic no longer makes these ballasts so mine needed to be rebuilt at the tune of $400.00.
With the ballast in place still nothing so now they claim that they need to order a "kit" from Panasonic which basically is all the components of my tv.
Jan 28, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Respond doc
Vulb,
Having had to change the lamp I would suspect the lamp thermal fuse is open... It's located over the duct for the fan housing and solders into the ballast board.. Check it for continuity and if open replace it..
There are several thermal fuses in that unit and not all of them as easy to access as the lamp one.
Good Luck
Bill
Nov 17, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-45lc problem
I took the rear bottom off of the set,lots of screws to take off.
On top of the bulb housing is a small yellowish thermal fuse.
I took mine completey out,jumped the black wire together,and bingo.set works perfectly.
Aug 31, 2007 | Panasonic PT-45LC12 45" Rear Projection...
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
