Computer sometimes won't turn on when i press the power button
I have a problem where my computer sometimes won't power on, usually it will 80% of the time, but 20% of the time pressing the power button doesn't do anything. When the computer refuses to power on i have to press the restart button for it to turn on. I have the power switch properly connected to the motherboard on the correct pins. Could it be the power supply or the motherboard?
More things i know about my computer:
  • The cpu has enough thermal grease, and the heatsink and fan are perfect (4200 rpm.).
  • The cpu is an Athlon XP 2700+ and its average temperature is 50 to 60 C on normal use, internet browsing word processing etc. sounds okay to me
  • I have cleaned the computer of all dust.
  • The power supply is an ANTEC brand pwr supply that came with the ANTEC chassis not sure about the model of the chassis. i have had many problems with these power supplies
I suspect that this is caused by the following in order of likeliness
  • a faulty power switch,
  • bad power supply,
  • maybe the cpu is overheating,
  • bad memory,
  • faulty motherboard
Thanks for your help in advance.
  • 2 more comments
  • stejeda777
    stejeda777 Feb 27, 2008
    oh hey thanks for the quick reply, to answer your question the computer is plugged in directly to a power brick that goes to a wall jack. no ups here
  • stejeda777
    stejeda777 Feb 28, 2008
    thanks when ill see if i can buy a new power supply im completely broke at the moment (im a pooor student with no job) but i think your right so ill give ya the rating since im not sure when ill be able to afford one. Thanks!
  • stejeda777
    By the way ill follow up and let you know how it goes once i find a good power supply.
  • Anonymous Apr 10, 2009
    was connected but no luck, can someone help me? My HP Desktop PC was froze so I turned it off and now when I push the on button, it doesn't turn back on, i checked that everything was connected but no luck, can someone help me?
    Genius:
  • 3,587 Answers
You are correct on one and two above, in your suspicions..how's your power from wall, and do you use a UPS?
check your computer warranty here 4 FREE
Posted on Feb 27, 2008
  • Patrick Michaels
    Patrick Michaels Feb 27, 2008
    the relationship between the power supply and the motherboard is vital. If you are experiencing soft failures of no turn on, that's a clear symptom that somethings soft inside that power supply. They are only around 30 bucks, so I recommend you consider getting a new one.
    if you data is important, consider an APC ups.
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
After connecting Bluetooth and turning on keyboard the blue light keeps flashing and the keyboard does not work
What kind of keyboard is it? Brand or model? Usually these are somewhere on the bottom of the keyboard or right on the front.
Sometimes it helps to completely power off the keyboard and try again, this means removing the battery from the keyboard and try to pair it with your computer.
If you aren't sure how to pair your keyboard with your computer that's where knowing what type of keyboard you have comes into play. Usually there is a button on the bottom to press for it to let your computer know it's available. Sometimes you have to do something else like press a certain combination of buttons.
Sep 11, 2014 | Computers & Internet
How do you know when the power supply is failing?
Actually its not the matter with the Power Supply,but with the CPU Cabinet Power Button.I recommend that you should replace the Cabinet.It will surely help,and for the freezing problem it's your Hard Drive problem,you can also try re installing Windows...!!
But for the Power Button problem you should definitely replace the cabinet
Aug 21, 2012 | ASUS A7V400-MX Motherboard
No power , computer will not turn on
Hi, IF the system is not turning on any more, try removing the power cable, then press the power button for 10 seconds. then try to power it on again . If it is still not powering up there could be an issue wiht the power supply of the computer. But if it start to turn on, like showing the Sony logo then windows but not going to the desktop. you can try to log on using safemode. you can go there by pressing F8 on the keyboard after turning on the computer. If it still not turning on even on safe mode. there couldbe an issue with the operating system of the computer and needs to be reinstalled.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Aug 20, 2011 | Sony VAIO V2M (VGCV2M) PC Desktop
My icons have disapeaerd since i deleted form ctrl alt delete.
if you press ctrl alt delete, sometimes the computer will reset itself. You might need to wait for a few minutes until the computer does its thing.
if the computer is not moving or you are getting impatient(I am usually impatient). I would usually press and hold the power button of the computer so it shuts down for me. Then I would press the power again so the computer will turn back on.
PLEASE BE WARNED - if you were doing something before this, you will lose your work, and there is a slight chance that the computer might not start back. If it does not start back usually it is a virus or a hardware problem.
May 18, 2011 | Microsoft Computers & Internet
When i press the power button on myn monitor i get a popup mon my screen "power button lockout" how do i solve this? i hve a window 7 hp computer. the power buton on the monitor was squeeze...
try..... it worked for me. Power Button Lockout is displayed.The monitor's Power Button Lockout function is enabled.
Press and hold the power button for 10 seconds to unlock
the power button function.
Thanks for using Fixya
Proton
Sep 11, 2010 | HP dx2300 Monitor Personal computer Intel...
What does the half moon lit up mean, No screen.
The half moon usually means the computer is in SLEEP MODE. Normally, pressing the spacebar will wake the computer up but I have noticed that sometimes, the computer can get "stuck" in sleep mode. If that is the case, you can hold the power button down (until the power turns off and the moon disappears). Wait a few seconds then hit the power button again to turn the laptop back on.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Won't turn on when I press the front button
This sounds like your power supply; it's the part that the power cord plugs into that converts the power to dc and powers your motherboard, drives, and everything else inside your computer. You can pick one up for around $30 online or $80 at a retail store.
Thanks and please take a moment to rate as fixya.
Sep 08, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
3,608 people viewed this question
Alun Cox
David Payne
David Payne
