Question about Mitsubishi VS-60601 60" Rear Projection Television
Resolution n clear screen for 60
I need both screens for my tv. can u please help me
  • 979 Answers
Are you wanting the cover and final exterior parts?
Posted on Feb 27, 2008
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
Why did my omni 100 disply screen shink, how do I fix it
ATI Radeon HD5450 graphics processing unit (GPU) soldered to the motherboard
Figure 3: GPU with fan
  • Interface: GPU chip soldered onto motherboard
  • Maximum resolution:
    • HDMI TV resolution: up to 1080p at 60 Hz*
    • HDMI PC resolution: 2560x1600 at 60 Hz
    • DVI TV resolution: up to 1080p at 60 Hz*
    • DVI PC resolution: 1920x1200 at 60 Hz
    • VGA resolution: 2048x1536 at 60 Hz
You need to use the ATI Catalyst Control Center software to optimize display.
See this page for the Omni 100 drivers
See HP Support
Aug 27, 2014 | HP Omni 100 PC
HOW TO PROGRAM THE 120 MHZ SCREEN RESOLUTION
The TV screen can only display what is sent to it, that in your case is 60hz. Bluray is 120hz and some DVD's.
Dec 29, 2011 | Samsung LN40A630 40 in. LCD TV
Screen Shakes on High Resolutions
your rate of refresh is too high, it's refreshing too fast, you need to lower the screen resolution. keep in mind, the tv resolution is much much smaller than a computer monitor. a computer monitor has much higher resolution. so Tv can only handle so much in resolution. if you need a better picture, it always the best to buy a monitor, not a tv for computer to get a good picture. if you have any more questions, let me know.
Oct 17, 2009 | Televison & Video
SCREEN SAYS OUT OF RANGE
I assume that you are using a DVI to VGA connection since this TV dose not have a DVI connection.
Make sure that the resolution are set to the following supported resolution:
1280 x 1024 @ 60 Hz
1024 x 768 @ 60, 75 Hz
800 x 600 @ 60, 75 Hz
640 x 480 @ 60, 75 Hz
Or just make sure its set to 1366x768 @ 60Hz
May 13, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Philips HDTV connected to pc, but has scrolling lines on screen
Did you get it to work for 1080i?
I never got my pc to work for 1080i in the first place. You should scour your settings program for the video card, try 1920x1080i or 640x480p.
The settings must exist because you got it to work in the first place. But if they were suddenly erased, powerstrip is a program that you can download, it gives you unlimited control over what resolutions you want to try, but if you're too aggressive it can break everything and force you to go back to a restore point. I can get it to work for the same TV as you with 640x480p but never 1080i, and if I try 1080i everything crashes.
Apr 13, 2009 | Philips 60PW9363 60" Rear Projection...
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
How do i connect my laptop
Assuming that the laptop is hooked up to the projection TV using the correct cables or connectors and still no video display on the TV, perhaps you need to lower down the laptops screen resolution first using your laptop's screen display before pressing the Fn + F? key.
To lower the screen resolution, right click on any clear area of your desktop, select Properties. click on the Settings tab, move cursor of Screen resolution to farthest left, Apply, Color Quality to lowest, Apply. Additionally, click on the Advanced button, Monitor tab, select lowest Screen refresh rate.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Pc connection doesnt work with computer
The TV you are hooking it to is not able to show the resolution you have the computer set to. Start by setting your computer resolution to 800 x 600. If that works than try 1024 x 768. If you go too high you will get that "out of range" message. The instruction book that came with your TV has a listing of the available resolutions the TV will show.
Aug 30, 2007 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
Sony PFM-42V1N 42 in. EDTV-Ready Plasma
Yea the TV supports Pal 60
I had to use the bnc connection to AV. but yeah the tv supports Pal 60 you need to go into the menu and select it
just the colours arnt very good on this TV
Mar 04, 2007 | Sony PFM-42V1N 42 in. EDTV-Ready Plasma...
Televison & Video Logo
15 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
