Question about Philips 50P8341 50" Rear Projection Television
The bulb recently burnt out. Need to replace it.
Need to replace the burnt out bulb.
How much would this cost and where/how do I do this?
Would it even be worth trying to fix it?
It's a Phillips Magnavox 50" projection TV, about 9 years old.
  • hollyberry44
    hollyberry44 Feb 27, 2008
    Hi Slint,
    The audio works but no picture. Do you have a ball-park figure of what this could cost to have a professional fix it?
    Someone wants to give this TV to me because they don't want to deal with it so I want to know if it's worth taking and if it can be fixed.
    Thanks so much.
    Holly
  • Philips Master
  • 8,617 Answers
Your set doesnt have a bulb. Its a crt projection unit. Is the set completely dead? If so troubleshooting the power supply is needed. If the audio works but no picture, then the deflection/HV circuits will need troubleshooting. Let me know if I can assist you further.
Posted on Feb 27, 2008
  • Sonny Berry
    Sonny Berry Feb 27, 2008
    thats hard to say. repair shops can be widely different. would say a reputable shop would be a couple hundred for a module and probably a couple hundred in fees diagnosis and labor. Around 400 would be close. But cant say for sure
2000 Maxima right passenger side headlamp does not work in low beam only, high beam ok. When I jiggled the harness cable (after replacing the bulb just in case) the lo beam would flicker on/off. Do I...
Dear,
dont buy any harness or module etc.
It is just because the bulb holder as burnt off............please get it changed will cost u very less
thanx
May 07, 2011 | 2003 Nissan Maxima
Tip
1999 Honda Accord Clock Burnt Out Light Bulb/Lamp Replacement
The Honda OE part number of the Clock Light Bulb2_bing.gif/Lamp replacement is # 35505-S84-N01. The part cost me $3.25 from a local Honda Dealer. A good site with instructions on how to replace the burnt out bulb is http://automotive.trevorated.com/
This part number may work for most G6 / 6th Generation Honda Accords, though I do know it works for my 1999 Honda Accord 4-speed automatic.
on May 07, 2010 | Honda Accord Cars & Trucks
Tip
1999 Honda Accord Center Console Gear Shift Burnt Out Light Bulb/Lamp...
The part number of the Light Bulb/Lamp replacement is # 74. The part cost me $5 for a Sylvania 2 pack from a local Auto Parts store. A good site with instructions on how to replace the burnt out bulb is http://automotive.trevorated.com/
My tv wont turn on and the lamp light comes on is it burnt out or do they need to be cleaned
if the lamp light is on, it means replace the projector bulb, they cost between 60 and 200 dollars and you must be careful when installing it, not to touch or rattle the bulb.
Feb 21, 2011 | Panasonic PT-61LCZ70 Television
Light inside dryer does not light up.
Your bulb has burnt out. Go to appliancepartspros.com put in your model number, in schematics on left side of page select #5 tumbler, bulb is part #7 cost $5.60. easy to replace, you just have to remove lens cover and replace bulb.
Aug 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I was stopped by a cop saying I had no taillights, I wasn't able to get to the mechanic right away, the next night my daughter had a similar experience- besides the bulbs, what else would I need to check...
Before buying a bulb/bulbs I would check the fuse box located in the engine compartment. Check the fuse labled 'tail lights' and 'stop lamp'. The fuse can burn out due to a faulty failed bulb. If the fuse is open (technical language for burnt) then don't replace it until you replace the bulbs as a faulty bulb probably caused it to blow. When bulbs die, they sometimes short out On the other hand - I recently had one tail light go out ( I was lucky and caught it and replaced the bulb right away). A week later the other one was burnt out. I'd bought a two pack of bulbs, and had put it in the glove box so the bulb was handy and no tools are needed to replace it. Just open the trunk and remove the cover behind the light. The socket comes out with a counterclockwise twist. Mine were in pretty tight so be careful if you use pliers to grab the socket as they're plastic. Pull the bulb straight out and get the exact replacement. The bulb number is printed in very small print on the bulb itself or on the socket depending on bulb type. The autoparts store clerk will help you get the correct bulb much faster if you have the old bulb in your hand.
Dec 13, 2009 | 2000 Toyota Camry
Fast blinking flasher
that means that one of your bulbs on that side is burnt out (either front or rear) most auto parts stores will replace the bulb for you at no additional cost
Nov 30, 2008 | 2008 Honda Pilot
No tail lights or brake lights
Check the relays associated with the tail lights, I believe that the tail light relay and the turn signal relay are two different entities. Hopefully that helps.
Jul 08, 2008 | 1999 Jeep Grand Cherokee
Vivicam 5386
It sounds like the bulb just simply burnt out. Before I spent any money on the camera, I would first reset the camera back to factory settings and try again. The cost of replacing the bulb might be more that the cost of a new camera!
Jan 30, 2008 | Vivitar ViviCam 5386 Digital Camera
Philips 50P8341 50" Rear Projection Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
