Question about Olympus FE-220 Digital Camera
Memory full I just got this camera, and once I charged the battery and then turned the camera on a screen came up that said "Memory Full". I find it quite odd that I haven't taken any pictures and yet the memory is full. That doesn't make any sense. somebody help? Eric
  • sissy51887 Mar 09, 2008
    i just bought my first digital camera and it is only letting me take 3 pictures then it is saying the memory is full. i have a Olympus fe-220. can someone please help me????
    Sami
  • 37 Answers
Hi Eric with new cameras they usually have to be formatted before any pictures have taken I dont know what kind of camera you have however the format button can usually be found under options. But formating your camera should cause your memory to jump up, if that doesnt work you may have to buy a memory card for it, these are called SD cards and they are usually not very expensive on Ebay around 12 dollars for one Gig.
Posted on Feb 27, 2008
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Feb 10, 2013 | Canon PowerShot SX110 IS Digital Camera
My camera stops working but the battery showed full.
Those are the symptoms of a battery that has been charged many times or has been allowed to completely discharge once or twice. Try some new ones.
Jan 06, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
extreme7528@yahoo.com
Oct 13, 2009 | Cameras
How can I tell what the level of charge is on the battery?
Once you plug the camera to the wall using the charger, the charging ligh will turn on, once it turns off, it means that battery is full.
Thanks.
Sep 27, 2009 | Kodak EASYSHARE M1063 Digital Camera
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
My camera is turning off
First clean all contacts in the battery chamber with a pencil eraser. Also clean the battery's contacts and try again. If you still get the same error, replace the batteries. It could be possible that the batteries have lost their full capacity.
Feb 10, 2009 | Olympus FE-190 Digital Camera
My canon is not powering on. I have the battery fully charged but nothing will turn on.
I had this problem with a Sony Digital Camera once. The memory card was full and it would not power on. I replaced the camera and was preparing to throw it away and tried turning it on one last time and only then did it briefly display a memory full error then quickly shut itself off.
I erased the memory and afterwards the camera worked fine.
So, check and make sure your memory card isn't full. If it is unload the contents onto your computer, erase it and try again.
Oct 20, 2008 | Cameras
Aiptek IS-DV
Try to format the card first
Dec 29, 2007 | Aiptek IS-DV Memory Card Camcorder
Not working
When you say 'Get the pictures' Have you actually or can you - down load them to the computer. If you can then go to menue and delete all the pictures. If the memory is full you have yo get those images off.
Jun 01, 2007 | Fuji FinePix F700 Digital Camera
Olympus FE-220 Digital Camera Logo
110 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
