Whirlpool AWM285-800 front loader
The bearings on the drum have become noisey
I have removed the pulley and the four bolts which seem to hold the bearing housing but cannot remove the housing even with a puller.
    Genius:
  • 3,587 Answers
That comes out when you pull the entire drum assembly, which means taking apart the cabinet/chassis. not for the rushed of time, or weak of arm muscles, I can assure you.
Posted on Feb 27, 2008
Tip
Drive Belt Installation on a Whirlpool Front Loading Washer
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Dec 10, 2009 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi there, my Indesit W133S front loader tub washing machine has stopped spinning, it made a funny metallic scratching sound mid cycle and then wouldnt spin. When I removed the washing even the empty drum...
Taking a guess is all that is possible...
The drum bearings have seized.
Something has broken and jammed the drum drive pulley.
Something has become jammed between the washtub and drum.
Your next step is to remove the top of the cabinet and examine the drive, ensure the motor still spins ok and the belt is intact, pulley not broken, etc.
If you find nothing wrong the task becomes fairly major as the cabinet will probably need dismantling in order to remove the front of the washtub for a closer inspection.
Mar 05, 2018 | Indesit W 123 Front Load Washer
Whirlpool duet sport elec dryer. Gets warms then sounds like change rattling in the external drum area. During warranty said tech was a screw that kept coming loose to the drum causing the noise. 2 yrs...
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 10, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Model #WFW 8300 SW01 (noise in drum on high speed-sounds as if it has a chain or something inside rattling. How do we get a manual or parts book?
the rear tub.
and tub assembly.
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front load duet washing machine. The white plastic around the drum is cracking and the machine is leaking from the front underside. Can this be repaired?
the rear tub.
and tub assembly.
Jul 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
Mod WFW 8400tw00 the bearing on the drum is out and the drum
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Outer-tub-item-number-AP3773839.aspx
Bearing NOTsold separately...
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum banging all through cycle, and much worse spinning
the rear tub.
and tub assembly.
Apr 07, 2009 | Washing Machines
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
