Question about Nikon CoolScan V ED Film Scanner
"The Scanner has reported a hardware error..."
"please reset the scanner by switching on and off. If this does not work, please contact your local nikon service or support office."
Owned for about 2 weeks about 50 4 frame negatives scanned. Any ideas? Problems this early tell me hardware, try for new.
  • Kathy Bombardier Sep 19, 2013
    not a hardware problem either
    If you would just read my last question you would see how easy it would be to answer it as it is not something you cant do to help me with this problem? It is the fact that b4 I clicked my finishedment
Version:1.0 StartHTML:0000000105 EndHTML:0000008195 StartFragment:0000002796 EndFragment:0000008159 Normal 0 0 1 464 2648 22 5 3251 11.0 0 21 0 0 I brought a coolscan 9000 the last month without the film holders, software etc just the scanner. A friend of mine sold me it for a good price. I run Leopard in a Powerbook G4 15” 1.2 ghz 2 Gigas ram. I installed the Nikon scan 4 and when I open it the scanner report an error: The Scanner has reported a hardware error... every time that I run the program this message appears. I thought that this was because I hadn’t got the film holders. When the film holders arrive from USA the same problem appears : The Scanner has reported a hardware error... Them I tried Silverfast Software. In this case the scanner report another error: there are not film holder ( or something like that). I uninstalled Nikon Software with the same utility to install it. Reinstall the Software and the same ****** problem. When I switch on the scanner a loud noise came from inside, after this the blinking light stopped and nothing happen ( no calibration, no light inside, nothing). Just one thing. The Scanner has reported a hardware error...
I checked on internet and the solution of switch it of and on doesn’t work. CALL TO THE NIKON SERVICE that’s was my only solution.
Of course I didn’t . The price of the scanner was 300 Pounds.
SO I OPENED IT.
I REMOVED THE SCREWS FROM THE BACKSIDE AND FROM THE BOTTOM OF THE SCANNER. I TOOK THE METALLIC CASE OF: PICTURE 1. After a while looking everything without touch I’m start to check for the connection cables one by one, WHEN DISCOVER THAT ONE CABLE PLUG THAT GOES FROM THE SCANNER TO THE FIREWARE BOARD WAS DESCONECTED…. PICTURE 2 Maybe on the shipping this plug looses his place. SO I SWITCH ON THE SCANNER AND THE PROBLEM DOESN’T APPEAR. Now the problem was that the film holder wasn’t recognising from the scanner. So I followed the steps that most frequently indicate on the web:
1-Close the scan program –
2-Turn off and unplug the scanner
3-Plug the LS9000 back in and turn it on
4-Reopen the scan program
The scanner worked. When I switch on the scanner take a minute or so to calibrate and determinate the film holder. Them I open the Nikon Scan 4 and every looked nice. I could scan my first negative ALELUYAAAAA. So I close everything without the screws so I put the scanner vertical to put back the metal case ones I finished I turned on the scanner and the Nikon program. For my surprise the same ******* error I couldn’t believe it.
I opened it again and I found the cause of the problem . BECAUSE THE SCANNER WAS ON VERTICAL BEFORE, THE METALLIC GUIDE THAT CONNECT WITH THE SERVO WAS MOVED (Move the scanner from one place to another may cause this issue) So with my finger I putted it in the same place. THE SCANNER WORK’S.
After this the only problem was a big loud gnashing and grinding noise that I sorted with CELOTAPE BETWEEN THE TWO PIECES THAT WAS SEPARATED BEFORE.
PICTURE 3
Now the scanner work fine. Sorry for my **** English and I hope that someone can find useful this information.
Posted on Sep 19, 2009
  • 37 Answers
If you have done what is says and still have the problem, uninstall the software and reinstall. 99% of the time this will do it. If not return it to the seller or send it to Nikon for repair. Did you buy it new from a dealer? If you've only had it two weeks it should be covered by warranty.
Posted on Feb 27, 2008
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
The device has experienced an internal hardware error.
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
Jul 09, 2011 | HP LaserJet 2840 Printer
HP-2727mfp scanner error problem
HPM2727mfp - Scanner Error 5 - Scanner Error 8
These errors indicate a problem with the flatbed scanner assembly. The flatbed is no longer able to initialize or find home position. The scanner may move back and forth continually and the light flicker at a high rate of speed. The flatbed scanner will need to be serviced/changed. The part required is CB532-67905
M2727SCANNER
Please contact your local Hewlett Packard Repair Center.
HPPARTNERLOCATOR
Jan 02, 2011 | HP Laserjet M2727nf Multifunction Printer
The light on the scanner is flashing intermittently hence it will not operate
When the light bar flashes or blinks, the built-in diagnostics are reporting the hardware is not functioning as expected; it does not necessarily mean the scanner is defective. Before contacting HP for service, perform the following:
  1. Turn off the computer.
  2. Disconnect the power cord and USB or parallel cable from the back of the scanner.
  3. Unlock the transport lock several times to ensure it is not restricting the movement of the carriage. Make sure it is fully open before proceeding to Step 4.
  4. Wait 60 seconds before connecting USB or parallel cable and the power cord to the scanner.
  5. Turn on the computer and rescan to test.
If the light bar flashing is accompanied by a 2117 error, also try the troubleshooting steps included in document: Bps03134 - Scanner not Responding 2093, Unidentified Program Error.
taken from hp support website
Jul 21, 2010 | HP ScanJet 5370C Flatbed Scanner
I am getting a notice saying hardware error Coolscan V ED
you must perform a p.o.s.t. reset. That is:
1) switch off the scanner
2) swithc off the PC
3) disconnect scanner from PC
5) remove the dia/film adapter
6) switch on tyhe scanner and wait untill it booted
7)insert the film/dia adapter
8) connect scanner and PC
9) switch on the PC
it should work now......
Jul 08, 2010 | Nikon CoolScan V ED Film Scanner
The scanner has reported a hardware error. Please reset the scanner by switching on and off. If this does not work please contact your local nikon service or support service office
Maybe this refer also the hardware faulures on a nikon 5000ED. I managed to repair them my self after being mischarged a couple of times at NIkon repair centre.
Please see some solutions I added on
www.scancare.nl/scanner.html
Different problems regarding a nikon 5000ed were shown.
regards
Andries Bos, www.scancare.nl
May 20, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon LS 2000 scanner is reporting a hardware error
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
Oct 29, 2009 | Nikon LS 2000 Film Scanner
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
The scanner output problem
replace scanner ccd or replace scanner cable
Mar 17, 2008 | HP ScanJet 2400 Flatbed Scanner
Scanner not working on my HP C4200 all in one
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
Dec 14, 2007 | Office Equipment & Supplies
Nikon CoolScan V ED Film Scanner Logo
1,897 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
